120,000+ miles still good for turbo???
Old Sep 16, 2002 | 03:43 PM
See Are X's Avatar
Default 120,000+ miles still good for turbo???
I might get another car, probably a second gen Integra...one thing I've noticed is that a lot of them have around 120,000-130,000 miles. Is that still safe for turbo???
Old Sep 16, 2002 | 03:59 PM
giooooo's Avatar
Default Re: 120,000+ miles still good for turbo??? (See Are X)
ask jinxproff99 he had likea 150k miles gsr and ran like 11's on a stock motor with boost.
Old Sep 16, 2002 | 04:23 PM
D-SPEED's Avatar
Default Re: 120,000+ miles still good for turbo??? (Giovannie)
go get a compression and cylinder leakdown test.
Old Sep 16, 2002 | 05:02 PM
integra-modder's Avatar
Default Re: 120,000+ miles still good for turbo??? (D-SPEED)
Old Sep 16, 2002 | 05:52 PM
dustin's Avatar
Default Re: 120,000+ miles still good for turbo??? (integra-modder)
If it runs fine you can boost it. At least that is my opinion.
I know I can sure ruin a car in 10k miles! hehe. Mileage doesn't mean anything.
Old Sep 16, 2002 | 06:06 PM
MyWhiteCivic's Avatar
I'm at 99k miles and my motor is still going good. But the trans on the other hand has seen better days. I knew this would happen though. Who knew an automatic tranny wouldn't like 10 lbs of boost?
Old Sep 16, 2002 | 06:15 PM
SIK IN DA HED's Avatar
New User
Default Re: 120,000+ miles still good for turbo??? (MyWhiteCivic)
i slapped on my kit at 115,000 miles.
Old Sep 16, 2002 | 06:30 PM
harryg's Avatar
Default Re: 120,000+ miles still good for turbo??? (dlplayboy)
miles aren't very indicative of the condition on honda motors
get the leakdown and compression tests and go from there
Old Sep 18, 2002 | 10:15 PM
nickb20vtec's Avatar
it should be fine! i put turbo on my 94 ls/vtec around 145,000 milese on it and it was fine! still is, its all about how you treat the car!
Old Sep 19, 2002 | 11:16 AM
Koori's Avatar
Default Re: 120,000+ miles still good for turbo??? (harrytg)
That is very true. My 95 Si has almost 140K on it, been turbocharged since it's second month.. I got it for 4K, couldn't beat it. Car is a champion. Honda's are very strange when it comes to mileage... I can't figure out why..
Old Sep 19, 2002 | 01:07 PM
synergy004's Avatar
Default Re: 120,000+ miles still good for turbo??? (Hadji)
i posted a topic on boosted motors with high miles. The out come of everyone was to do like what was said above and do the tests. Do the routine maintenance on the ride and then you can join the dark side. honda/acura motors are pretty stout and should hold up if the motor is up to it. Every motor is different like fingerprints. No two can be identicle unless engineered with precision at the same time.
brent_si
Apr 16, 2007 12:22 PM
phish4709
Apr 15, 2007 07:02 PM
Garbonzon311
Jan 26, 2004 10:54 PM
slow hatch
Feb 22, 2003 08:02 PM
sa21199
Oct 10, 2001 04:47 PM
