3/16th brake line for turbo feed. restrictor needed?
Old Aug 3, 2010 | 04:41 PM
machine4321's Avatar
Default 3/16th brake line for turbo feed. restrictor needed?
budget build(real real budgetlol) and i have some 3/16th brake line around. I was wondering if i wil need a restrictor with line that small?
Thanks
Old Aug 3, 2010 | 08:02 PM
dantamparacer's Avatar
Default Re: 3/16th brake line for turbo feed. restrictor needed?
Depends on what turbo you have. A 3/16 brake line is very close if not the same as a -3 an line.
heres a link that explains the conversion
http://www.jdaent.com/an-army-navy-dash.html
Old Aug 4, 2010 | 04:13 AM
Its a OEM turbo of some sort(87 T-bird comp housing, just not sure on the exh housing ). havent been able to get e straight answer what it is from. The hard line that is on the turbo is larger then 3/16th. mabye 1/4 inch
Old Aug 4, 2010 | 05:07 PM
can you read anything off of the housings? What ever car company used it on there cars probably bought it from an outside company
Old Aug 4, 2010 | 05:48 PM
hybrdthry911's Avatar
-x = x/16 so yes -3 = 3/16", -4 is 1/4", -8 is 1/2" etc... yes even with a line that small an oil restrictor is usually necessary.
Old Aug 5, 2010 | 03:45 PM
Dam. now i need to find one of them . I may just crimp the line in a few spots lol
Nermin
Oct 10, 2010 08:30 PM
turbo boost
Dec 18, 2006 05:09 PM
Soda Popinski
Dec 31, 2005 12:28 PM
turbospool
Aug 10, 2003 11:38 AM
