Honda Acrua JDM ITR Transmission, Helical LSD Look!
For sale are the guts of a JDM ITR trans. Here is the story behind these parts. This was pulled from a friend's B16 supercharged Civic. For the last few thousand miles driving on this trans there was a whining noise which continued to increase until the car would no longer go into gear. The car was then loaded onto a car trailer and the trans case hit the trailer and cracked the case (hence no trans case). After disassembly we found that the ring and pinion gears where stripped which caused the problem. Here is a great chance to use your existing ring/pinion and final drive gear with the LSD and the JDM ITR gearing. This was a hydro trans. Please do your research!! I don't have the knowledge to tell you what parts will or will not work in certain cases. As you can see in the pictures there is one alignment pin broken off the LSD but the gearing inside is in perfect shape. The LSD should fit GSR and ITR trans w/o modifications but again, please do your own research. I will sell complete or separate or trade? Taking offers.
http://i13.photobucket.com/albums/a2...D/DSC09597.jpg
http://i13.photobucket.com/albums/a2...D/DSC09615.jpg
http://i13.photobucket.com/albums/a2...D/DSC09611.jpg
http://i13.photobucket.com/albums/a2...D/DSC09604.jpg
http://i13.photobucket.com/albums/a2...D/DSC08962.jpg
http://i13.photobucket.com/albums/a2...D/DSC08959.jpg
http://i13.photobucket.com/albums/a2...D/DSC08955.jpg
http://i13.photobucket.com/albums/a2...D/DSC08953.jpg
http://i13.photobucket.com/albums/a2...D/DSC08951.jpg
http://i13.photobucket.com/albums/a2...D/DSC08943.jpg
Outsane
Apr 23, 2006 09:49 PM
GLWS
