Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
CorSport Bushings Cable/Shifter Bushings
Old Aug 3, 2010 | 01:11 PM
corsport's Avatar
Default CorSport Bushings Cable/Shifter Bushings
Help your shifter feel the way it should with CorSport Bushings.
Corsport Cable Bushings Link
Corsport Shifter Bushings Link
CorSport Aluminum Performance Shifter Cable Bushings
This aluminum shifter bushing kit will help to tighten the feel of your shifter by eliminating the stock rubber bushing in the shift cable where it connects to the transmission, these are sometimes referred to as "under hood shifter bushings".
After time, the stock rubber and metal sleeved bushing will wear and deteriorate, making the shifter feel less precise and slowing down your shifting times!
These precision machined performance aluminum solid bushings give you back your shifters feel, they enable very tight and crisp shifting.
CorSport Aluminum Shifter Base Bushings
These aluminum spacers replace the rubber bushings that provide the basis for the excess movement in the shifter mechanism. By simply replacing the rubber with aluminum you create a much more exact and precise shift. It increases the overall feel of the shifter mechanism noticeably.
Note: It's a very simple install that takes a little patience and calm hands. Shipped out with instructions, also available as a .pdf file upon request.
Old Aug 10, 2010 | 09:46 AM
corsport's Avatar
Default Re: CorSport Bushings Cable/Shifter Bushings
Plenty in stock for tons of applications.
Old Aug 10, 2010 | 03:56 PM
phatrick2332's Avatar
What do you have for an ee4?
Old Aug 11, 2010 | 08:11 AM
corsport's Avatar
The old ee4 huh, yup, the ee4.
Whats a ee4? lol
Old Aug 12, 2010 | 09:39 AM
corsport's Avatar
Plenty in stock.
Old Aug 16, 2010 | 11:07 AM
corsport's Avatar
Tons of apps.
Old Aug 18, 2010 | 09:49 AM
corsport's Avatar
Old Aug 24, 2010 | 09:47 AM
corsport's Avatar
Old Aug 31, 2010 | 10:54 AM
corsport's Avatar
Old Sep 7, 2010 | 11:45 AM
corsport's Avatar
Always available.
Old Sep 14, 2010 | 09:48 AM
corsport's Avatar
masospaghetti
Sep 9, 2014 03:56 PM
BDM
Sep 24, 2009 02:16 AM
square_1
Jan 31, 2009 09:26 PM
pitchblacksi
Honda Civic (2006 - 2015)
Apr 9, 2007 03:46 PM
CivicRaping
Jun 8, 2005 08:08 PM
