CRX TRANS (HELPPP!!!!)
whats up ma trans is making a noise when the clutch out when i push it in it stops.. i thought it was the throw-out bearing..soo i bought a new n i had put it in but its still making the noise idk what it is... sounds like somethins lose in da trans.. can the trans b messed up?? its drivin me crazy i dont get it i put the clutch in n it stops..PLEASE HELP ME..THANXXX
juss curious..how much was it to have someone replace that throwout bearing? cause im guessing around 600 bucks..if you went to an actual shop. thats alot of work just to swap the throwout bearing itself
Lulz, it's the input shaft bearing. A little noise is normal. Drive it until it breaks and then replace the transmission. Or pull it out now and rebuild it.
tegtuner94
May 17, 2005 07:20 PM
