Suspension & Brakes Theory, alignment, spring rates....
swaybar?
Old Aug 2, 2010 | 09:35 PM
manoloek9's Avatar
Default swaybar?
ok i bought a subframe for my ek hatch and one of my friends is selling me a swaybar for the rear so i have the option to get a gsr or a si from him which is better??............... with blox LCA's
Old Aug 3, 2010 | 06:42 AM
98civdx's Avatar
Master Detailer
Default Re: swaybar?
Either one, I think the gsr is 14mm (maybe 15) and si is 13mm.
I highly doubt you will feel a difference in the two.
Old Aug 3, 2010 | 11:06 AM
Relic1's Avatar
EK SI = 13mm
DC2 GSR = 14mm
larger the better IMO
Old Aug 3, 2010 | 11:50 AM
98civdx's Avatar
Master Detailer
You really think your going to feel a 1mm difference?
Old Aug 3, 2010 | 02:32 PM
manoloek9's Avatar
koo gsr bigger but i thinks it will b better 1mm should make a difference or should i just get an eibach swaybar for si or gsr?
Old Aug 3, 2010 | 03:06 PM
STOCK_SOHC_DX's Avatar
Well the Si bar fits perfectly so that gets my vote. I would stay away from the Bloxs LCA's
Old Aug 3, 2010 | 03:42 PM
98civdx's Avatar
Master Detailer
I have the si bar, and i am happy with it.
Im interested to hear some other opinons but it's only a 1mm.
Old Aug 3, 2010 | 04:29 PM
lzyga09's Avatar
x2
imo get a itr sway from a dealer + a sub-frame brace
Old Aug 3, 2010 | 04:35 PM
Drive 4 fun's Avatar
Ok, I will try this. Assuming all similar except radius/diameter of the bar, the stiffness is, if I remember correctly, proportional to radius to the 4th power. From 13 to 14 mm diameter is about 7% larger radius. I believe that it comes out about 30% stiffer.
Old Aug 3, 2010 | 06:33 PM
manoloek9's Avatar
koo gsr it is.........but why stay away from blox lca? Why they no good? Wats better?
Old Aug 3, 2010 | 08:08 PM
I think best LCA's are Function 7's. You can check availability for your EK.
Old Aug 3, 2010 | 08:28 PM
95skunkedgsr's Avatar
the bloxs lca's have the location where you mount the sway bar up in the wrong spot you will need adjustable end links
Old Aug 4, 2010 | 08:22 AM
kristo's Avatar
Loved
Stick to OEM parts and model-specific bars.
Old Aug 4, 2010 | 01:20 PM
manoloek9's Avatar
stock lca it is i guess fits better
Old Aug 5, 2010 | 01:29 AM
get a f7 lca or skunk2 if you realy want one, those both have the mounting spot in the right place
Old Aug 5, 2010 | 05:42 AM
phunhaus's Avatar
If you're running an Si sway bar you don't need a subframe reinforcement.
Old Aug 5, 2010 | 08:03 AM
kristo's Avatar
Loved
Correct, in the sense of some aftermarket brace like ASR.
However behind the subframe mounting holes some reinforcement is needed as is stock on SI and EK4, and what purpose is served by the ASR 'backing plates'.
SuperCivic
Jul 22, 2004 03:04 PM
Kronic
Feb 9, 2003 09:41 PM
tinkfist
Sep 27, 2002 06:17 PM
White Lightnin
Jun 26, 2002 10:08 AM
gubo22
Nov 12, 2001 06:56 AM
