the ef hatch cheap build 500whp??? hoping
Old Aug 2, 2010 | 09:26 PM
ww3slayer's Avatar
Default the ef hatch cheap build 500whp??? hoping
so i just got this dpfi 90 ef hatch shell for $200 it has coilovers and si seats. its blue and has NO dents. i have this d16z6 that i am building will post pics of the build tomorrow.
Old Aug 2, 2010 | 09:28 PM
ryanevansoh's Avatar
Default Re: the ef hatch cheap build 500whp??? hoping
cheap and 500whp? thats gonna be tough
Old Aug 2, 2010 | 09:54 PM
ww3slayer's Avatar
Old Aug 2, 2010 | 09:58 PM
ww3slayer's Avatar
not really i have a lot of parts that i can trade and i know a lot of people that work at shops all i have only paid $200 all together and i have a semi built d16z6 it has eagle H beams and wiseco pistons i got it on trade for a blown ls with arp head studs.
Old Aug 2, 2010 | 10:03 PM
D16SiHatch's Avatar
better do some port work and have a big *** turbo if you hope to make 500. and i would certainly not recommend aiming for a number that high with stock sleeves either.
Old Aug 2, 2010 | 10:14 PM
.Manny.'s Avatar
Touching My Member
In for 250whp.
Old Aug 2, 2010 | 10:50 PM
ww3slayer's Avatar
im getting a block guard and a gt35r turbo for $120 got my new gasket set for $15 today and im getting a bisimoto 3.6 cam and cam gear.
i dont think 500whp is hard its all how you build the motor and the tune im getting it tuned by a guy that i sold my old car too and he works at a shop and tunes and turbos cars all the time. i got a lot of stuff for free like my tranny, flywheel, mounts, axles and gsr TB. im going to p&p tomorrow if i have the time.
Old Aug 2, 2010 | 10:55 PM
ww3slayer's Avatar
the $15 gasket still in the plastic and its all the gaskets
the yakima racks there for sale to pay for the project
Old Aug 2, 2010 | 11:21 PM
D16SiHatch's Avatar
a 35r for $120? how the hell did you manage that.
what made you decide to use a blockgaurd? i've found numerous occasions where people have made awesome numbers safely without it. i personally feel that it does more harm than good. but i mean thats just me anyway.
Old Aug 2, 2010 | 11:25 PM
ww3slayer's Avatar
my dad used to drag when he was younger and he still talks to most of his friend and they all know me and im getting a deal cuz im his son and its rebuilt.
do they really make your engine run hot and i think im going to just use the stock sleeves i think if i only go to 500whp ang a good tune ill be ok but idk im reading in on the single slammer thread.
Old Aug 2, 2010 | 11:29 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
lose the block guard.
Old Aug 2, 2010 | 11:38 PM
ww3slayer's Avatar
ok will do i still need a turbo manifold idk if im going to go all out for flow or go cheap cast iron?
Old Aug 3, 2010 | 12:01 AM
mattliston's Avatar
500whp can be had for less then 2500
will it last a long time? no. the motor will be okay, but the turbo kit will not be durable
you can make a rock solid motor for less then a grand
Old Aug 3, 2010 | 02:29 AM
ww3slayer's Avatar
my turbo kit is going to be a ok i guess im still trying to find some cheap injectors and an intercooler.
Old Aug 21, 2010 | 10:35 AM
ww3slayer's Avatar
Old Aug 21, 2010 | 01:50 PM
75euRFE's Avatar
you could try posting your block. a lot of people believe it is a better alternative to the block guard. it is also inexpensive to do. and since the d series motors already have a lot of angularity with the 1.52:1 rod stroke ratio, this will at least help with distributing some of the flexing from just the cylinder walls to the outside walls of the block as well. just an idea.
good luck on your build.
Old Aug 21, 2010 | 10:35 PM
ww3slayer's Avatar
how do i post a block i have never heard of that before?
Old Aug 22, 2010 | 05:30 AM
75euRFE's Avatar
you tap into the side of the block at certain points and insert threaded studs that touch the side of the cylinder walls. these studs will distribute the load from just the cylinder walls to the outside of the block. Meaning in order to move the cylinder walls you have to move the outside of the block as well.
This thread is pretty detailed. Check it out.
https://honda-tech.com/forums/showth...=Posting+block
Old Aug 22, 2010 | 09:30 AM
ww3slayer's Avatar
that would seem to me like it would weaken the block but it looks good ill look more into it thanks. i just got an 88 crx si for 450 today and its got a z6 swap ill post some pics later
Old Aug 22, 2010 | 09:36 AM
75euRFE's Avatar
posting has been done for a few decades (all the way back to the 60's if not even further back) so I think that should speak for itself. but take it as you will. nice find on the crx btw, and again, good luck with your build,
Old Aug 22, 2010 | 06:14 PM
cloviskilla's Avatar
500hp? u better get rid of that caca headgasket and caca clutch. motor looks good. except the vitaras are in backwards lol
Old Aug 23, 2010 | 12:27 PM
ww3slayer's Avatar
got the block as is so havent had time to do anything to it i got from this stupid kid that was thinking his stock dpfi was faster than a b16 lol
N'viouzEF9
Jan 23, 2011 08:19 AM
kevs-ej1
Aug 4, 2010 07:12 PM
myflyintegra
May 5, 2010 11:10 AM
The Droogan Leader
Aug 6, 2008 06:29 AM
SMOOTHN
Appearance Build Threads
159
Jun 17, 2008 06:51 AM
