Turbo B18B Valve Adjustment
I'm running a stock internal B18B setup pushing 7 psi, 230 whp. My motor is due for a valve adjustment. Seeing as it's stock internals I would assume I should use the stock valve adjustment specs but here is my question. Should I adjust them on the tighter side or the looser side of the allowances seeing as it's boosted. Thanks.
