Accord seat belt warning beep
Old Sep 16, 2002 | 02:15 PM
TnVol's Avatar
Default Accord seat belt warning beep
In our 91 Accord, the drivers side shoulder belt gets stuck in the forward position. I checked the fuse and it's not blown. I manually cranked the belt back into the locked position and disconnected the power to the motor so it wouldn't take the belt forward whenever I opened the door. The warning light on the dash keeps flashing and beeping as if the belt wasn't in place. I was told their was a way to stop this. Is this so? Or, if it's inexpensive, is there a way to fix this?
Old Sep 16, 2002 | 03:47 PM
joeyd's Avatar
Default Re: Accord seat belt warning beep (TnVol)
Honda has to fix the seatbelt mechanism if its not working properly...as long as you havent messed with it in any way...bring it back to a Honda dealer and they should fix it for free
Old Sep 16, 2002 | 03:48 PM
GimpyAccord's Avatar
Default Re: Accord seat belt warning beep (joeyd)
in the meantime if the beeping annoys you unplug the quick connectors on the box under you passenger seat. that is the auto seatbelt brain.
i just locked mine in the back position, and pulled the plugs years ago.. i hate electric seatbelts.
Old Sep 16, 2002 | 08:45 PM
90H22's Avatar
Default Re: Accord seat belt warning beep (GimpyAccord)
Ahhh, I hate "Seatbelts of Death". I'm always in a rush and that doesn't work too well with auto belts when you try to jump out of the car really quick. I nearly hung myself every day jumping out of my 90 when it was running. Darn DeathBelts!
Old Sep 17, 2002 | 08:04 AM
SearchBeforeUPost!'s Avatar
Default Re: Accord seat belt warning beep (Two1Accord)
i just went through this with my accord. honda says they don't have to fix it. My seatbelts worked, but the light still flashed and the beeper went off. so i took the light out of the dash cluster, and the beeper out of the seatbelt computer.
Old Sep 17, 2002 | 08:54 AM
Default Re: Accord seat belt warning beep (Bda91acc)
I have never tried to get mine fixed, but I always thought auto companies were required to fix passive restraint systems (like airbags etc) ???
Old Sep 17, 2002 | 02:47 PM
TnVol's Avatar
Thanks - It worked like a charm
awalle
Jan 26, 2015 03:06 PM
AJHondaAcc90
Jun 13, 2014 05:19 AM
gatorfish
Nov 17, 2010 06:27 AM
civicracer1600
May 5, 2007 05:22 PM
Susie67
May 4, 2006 11:27 PM
