code 4 and limp mode after mpfi
Old Aug 1, 2010 | 03:35 PM
scottso990's Avatar
Default code 4 and limp mode after mpfi
Hey i just did a mpfi swap on my ef hatch.
Im now throwing a code 4 (Crank position sensor) and my cars in limp mode.
I triple checked the wiring for the distributor and i know its correct.
Is there any other reason I could be throwing this code?
Could it be the wrong or broken dizzy? Wuts the distributor code for d16a6?
Could it be a bad ecu? Thanks in advance for everyones help.
Old Aug 1, 2010 | 04:06 PM
scottso990's Avatar
Default Re: code 4 and limp mode after mpfi
bump
scottso990's Avatar
help please i need this fixed asap so i can drive it to school
Old Aug 1, 2010 | 04:31 PM
CRXSIPower's Avatar
If your sure everything is wired correctly, sounds like you need a new dizzy, crank sensor is non replacable part inside the distributor.
Old Aug 1, 2010 | 04:37 PM
scottso990's Avatar
Originally Posted by CRXSIPower
If your sure everything is wired correctly, sounds like you need a new dizzy, crank sensor is non replaceable part inside the distributor.
thats what I think the problem may be but i just wanted to check to see if there may be something else that could cause the issue before I buy a new dizzy. I wish i had a known good dizzy that i could try out. Thanks for your help
Does anyone know what code for the dizzy u use for mpfi?
Old Aug 1, 2010 | 05:46 PM
scottso990's Avatar
ttt
scottso990's Avatar
tryin to fix this in tthe morning please help
Old Aug 1, 2010 | 05:47 PM
scottso990's Avatar
I have another dizzy that i think has somethin wrong with it but not sure. If i use it as a donor wut should i try changing?
Old Aug 1, 2010 | 08:33 PM
scottso990's Avatar
anyone else have some input?...............(34)
i just confirmed the firing order is correct(12) and it is the correct dizzy (td-02u)
Old Aug 2, 2010 | 04:38 AM
scottso990's Avatar
ttt
Old Aug 2, 2010 | 12:54 PM
scottso990's Avatar
I put in another dizzy today and it cleared the code 4 and now i have a code 9 for cylinder 1 position so I guess that means it was the dizzy so now i just need a new 1
88efsedanlx
Dec 10, 2011 05:40 PM
jedb18
May 31, 2008 12:32 PM
som3on3_10
Nov 5, 2007 08:31 PM
Spade
Jul 30, 2002 02:05 PM
