VTEC solenoid gasket - installation - wet or dry?
Old Jul 31, 2010 | 07:23 PM
rude_88's Avatar
Default VTEC solenoid gasket - installation - wet or dry?
So should I pre-lube the gasket before installation? I did but I still am seeing some oil and I don't want to over-tighten the bolts and have them break. So my next step in trying to get this leak fixed is replacing the cam seal, already got the o-ring done on the distributor.
Thanks in advance!
Old Jul 31, 2010 | 07:52 PM
Apex1972's Avatar
Default Re: VTEC solenoid gasket - installation - wet or dry?
a little oil on the new gasket is a good idea. spray the area with brake cleaner after you get done and it will be good and clean. then look to see if you still have a leak after you test drive.
Old Jul 31, 2010 | 08:04 PM
rude_88's Avatar
Good so the oil on the gasket was not a mistake, I've broken bolts before and maybe I'm just being a paranoid pansy about torquing them down!
Old Aug 3, 2010 | 05:00 PM
rude_88's Avatar
Just a little bit more info turns out the cam seal was leaking. After that my engine is dry as a dead dingo's donger.
Old Aug 8, 2010 | 04:36 PM
Lude #1's Avatar
yea my cam seal was completely shot and oil was leakin outa that ***** like crazy. replaced it with a golden eagle cam cause it has 3 o-rings rather than the OEM 1 that has 1 o-ring and no leak.
dwkt
26
Apr 2, 2013 12:57 PM
jeremypr
Aug 2, 2009 05:05 PM
danielblushtein
Mar 16, 2009 12:33 PM
ZC88CRX
14
Aug 1, 2004 02:02 PM
DXsiRII
Oct 20, 2003 07:55 PM
