Cap and rotor replacement
Old Jul 31, 2010 | 11:56 AM
BlaccPlasticc's Avatar
Default Cap and rotor replacement
I am about to change out the cap and rotor on my 94 Accord EX, I have heard the only real problem might be when the rotor bolt is in a position where it's hard to get to. How do I get that bolt in position to take off? Can I just crank the car real quick to make it move, even if the cap is already off but still has wires attached, or is there a way to manually move it? Also, is there something to be aware of in regards to the #1 piston being TDC(top dead center)... does that even matter with this or do I just put the cap and rotor back in the exact same positions as when I took them off? If so, how do i make sure of the TDC?
Old Jul 31, 2010 | 12:16 PM
HonBeer's Avatar
Default Re: Cap and rotor replacement
OMG! Really?
Old Jul 31, 2010 | 12:25 PM
Originally Posted by HonBeer
OMG! Really?
What's your problem? Can I get someone with some sense?
Old Jul 31, 2010 | 12:45 PM
JoeBull's Avatar
You can just bump the motor, meaning turn the key and let it crank for just a second. The rotor only goes on one way. Before yot remove the wires draw a diagram of how the go. Check the old cap gasket for oil damage and check the bottom of the cap and inside the distributor for oil. If you find any you will need a new internal distributor seal. Also check the block near the distributor housing for oil if you find some you may need a new distributor O-ring. These parts tend to go on the Accord.
Old Jul 31, 2010 | 01:19 PM
Thanks Joe
Brett
Oct 24, 2007 07:55 PM
xstalkrx
May 21, 2007 04:34 PM
Kg cm2
Jan 11, 2003 09:43 AM
avs
Jul 19, 2002 12:20 PM
93SSPHatch
May 31, 2002 04:13 AM
