antitheft system cadillac CTS
Old Jul 30, 2010 | 08:04 PM
Dead CIVIC's Avatar
Veteran: Army
Default antitheft system cadillac CTS
im desperate i need help.
http://www.cadillacforums.com/forums...8-harness.html
anything is apreciated thanks.
Old Aug 1, 2010 | 05:33 AM
audioroach's Avatar
Default Re: antitheft system cadillac CTS
I read your post.....
Short answer is your Pooched plain and simple.
It would appear that you cut the main engine harness/BCM wires by accident and may have damaged a few modules. The BCM isn't seeing the signal from the system that the brakes are pressed and the car is in park to release the key.
Sorry
Old Aug 2, 2010 | 03:02 PM
Dead CIVIC's Avatar
Veteran: Army
good answer thanks. i've asked a numerous amount of time to different official dealers and it seems it's the anti theft... i really hope it is. i will be taking the car next week. i hope nothing got burnt.
Old Aug 3, 2010 | 01:27 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Check twice drill once.
Go threw the fuse box and make sure that there is no fuse burnt on the brake circuit. Also can you post a pic of what harness you drilled thru. Then I can see what circuit that you fubar. I work will my local caddy dealer on mobile work and video and can get the schm to it. Also do you have the spare key? Put the spare in and lock and unlock the door to see if you can reset the alarm. Prey that its not the bcm because thats a $500 and up fix.
elouadj
Apr 2, 2010 01:35 PM
bobmugen
Audio / Security / Video
Apr 9, 2008 04:02 PM
SpoonyGSR
Jun 17, 2005 10:35 AM
dabiddan
Nov 23, 2004 11:08 PM
Drizzo
11
Feb 24, 2004 05:10 PM
