Rubbing Noise Hard Cornering
Old Jul 30, 2010 | 03:58 PM
hludke's Avatar
Default Rubbing Noise Hard Cornering
Ok I just replaced passenger side transaxle and ball-joints etc on my 2000 Honda Accord. I have Koni Yellows, Einbach Pro-sports Springs 1.2” drop . Once I installed the new axle with CV joints I get this load thumping or knocking noise when making hard left turns. It almost sounds like the ABS system is rubbing.
Any suggestions what to look for.
Old Jul 31, 2010 | 12:32 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Rubbing Noise Hard Cornering
Did you purchase NEW axles or reman'd units? The reman'd units can be a crap shot. Did you removed any part of the inner fender? Are you sure you put it back correctly?
Old Jul 31, 2010 | 11:54 AM
hludke's Avatar
Yeah this axle was a re-furb from AutoZone. All the inner plastic is back in place and there is no tire ware that I can see.
Old Jul 31, 2010 | 01:53 PM
MAD_MIKE's Avatar
MM Gruppe B
If you search Autozone here you will find that their re-furbished axles are shoddy. I've had good results with new Cardone brand axles. They are cheaper than the reman'd units and do not require a core.
Does the sound change if you are applying gas, cruising, or braking while turning left?
Old Jul 31, 2010 | 04:51 PM
hludke's Avatar
I will check out those Cardone's because the driver side will be due for relpacement soon.
The noise only ocuurs when hard cornering ( down force on the side the axel was replaced); sounds like someone is holding a scrediver on those tabs on the ABS sproket.
Old Jul 31, 2010 | 05:13 PM
lazlong's Avatar
bad wheel bearing?
Old Jul 31, 2010 | 10:55 PM
holmesnmanny's Avatar
Does it sound like a cotter pin grinding metal to metal?
Old Aug 1, 2010 | 12:28 AM
cctgene's Avatar
Any chance your axle nut was not torque to specifications?
Old Aug 1, 2010 | 02:45 PM
MAD_MIKE's Avatar
MM Gruppe B
Can you check to see if the tabs have witness marks or shavings sticking to them?
Raise the car up and check the front wheel bearing. Push and pull at 3 O'clock and 9 O'clock positions, and do the same at the 12 and 6 O'clock positions. Check both sides. There should not be much play in 3 and 6(steering components will allow a bit of movement) but 12 and 6 should be relatively solid.
Old Aug 1, 2010 | 04:44 PM
hludke's Avatar
Ok so I took the whole thing apart and I noticed there was very little clearance between the top of the ball joint and ABS sprocket, it was rubbing on the top off the ball joint. Thanks again to my friends at Kragen for selling me the wrong ball joint or there Installation tool not working properly. I will be visiting them tomorrow for the $43.00 Moog ball joint rather that the cheap one they sold me.
Old Aug 1, 2010 | 10:41 PM
02 accord's Avatar
It's weird that it would only rub under hard cornering. When the suspension gets compressed, the wheel/knuckle move up while the LCA is being pushed down by the spring. That should pull the ball joint in the knuckle downward, away from the axle.
The only thing that would explain your situation is play in the bearing. The play would allow the wheel to camber on the bearing, moving the outer CV joint downward and onto the ball joint.
Old Aug 2, 2010 | 05:20 PM
hludke's Avatar
Yes I think you nailed it; there is about a 1/4 to 1/2" play at the bottom of the ball joint. I am fixing it now.
dlewis2583
Jan 25, 2011 05:41 AM
LOC714
Apr 28, 2006 12:31 AM
Riceintegrars
May 31, 2005 07:27 PM
lowRIDAH
12
Dec 27, 2004 09:05 AM
flip1199
Oct 24, 2002 10:58 AM
