Suspension Problem Ej1
Old Jul 30, 2010 | 05:37 AM
tigerwing's Avatar
Default Suspension Problem Ej1
Hi Bros,
The Car is a: Honda Civic 1994 USDM Coupe
My problem this time is: when i lowed my car with TEIN S-Tech Springs, the car looks great, but the side of the driver both side, rear and front, was more low that the other side of passenger... :S
On Passenger side has 2 fingers from the tire, on driver side has 1/2 finger from the tire...
what do you think happend here?... maybe something damaged?, arms?, bushings?, Ball joints?...
my setup is: all stock, shocks KYB OEM, trailing arm bushing by Energy Suspension, TEIN S-Tech Springs.
Old Jul 30, 2010 | 06:20 AM
tigerwing's Avatar
Default Re: Suspension Problem Ej1
up!
Old Jul 30, 2010 | 10:40 AM
tigerwing's Avatar
anyone can help me please?
Alguno puede ayudarme plz?
Old Jul 30, 2010 | 11:13 AM
D Griff's Avatar
Are the springs brand new? I have s techs on koni yellows and mine sits a tad lower on one side as well. It's not that noticeable though. I think tein products might just not be very good.
Old Jul 31, 2010 | 04:04 AM
tigerwing's Avatar
yeah springs are brand new... i dont think is springs... cuz before low the car, the car was exactly with that problem, with oem suspension....
another think that could be?...
respect!
Old Aug 2, 2010 | 12:01 AM
lome1232's Avatar
I have the same problem my left side sits lower then my right side, its the shock absorbers that are worn out. I commute everyday and i drive bymyself so its obvious that over time the left side suspension will wear out more then the right. What I am trying to find out is if the right side strut can be swapped with the left side.
Old Aug 2, 2010 | 01:39 AM
tico's Avatar
well u are fairly close. its actually the entire suspension wears more on the driver side, but mainly the bushings... after time they keep their normal driving position.. only way to correct is adjustable coilovers which isnt fixing the problem just masking it or replacing all or bushings with poly-urathane bushings.
Old Aug 2, 2010 | 07:08 AM
tigerwing's Avatar
ok tico, i will do that... Energy Susp. for all the car...
then i will tell u how is it going!....
thank you...
any other suggestion ?...
Old Aug 2, 2010 | 09:04 AM
lome1232's Avatar
What are a good brand for poly-urathane bushings? I also want to replace ball joints and tie rods, do you know where i can get something better then OEM?
Old Aug 2, 2010 | 12:22 PM
tigerwing's Avatar
Poly-Urethane = Energy Suspension
Ball J. and Tie Rods = OEM (the best)
respect!
ZAKU
Suspension & Brakes
Feb 24, 2009 12:01 AM
Bulli Kid
Feb 11, 2007 11:04 AM
slow94civic
10
Apr 17, 2006 06:40 AM
SalHonda95
Suspension & Brakes
Mar 14, 2005 02:15 AM
216.226.142.95:27016
May 1, 2003 08:22 AM
