d16a1 dohc questions!!
Old Jul 29, 2010 | 08:11 PM
Honda-ls-hatch's Avatar
Default d16a1 dohc questions!!
What is the comppresion ratio of the d16a1 dohc?
Is it fine to boost it stock on about 7-9 pounds?
Old Jul 29, 2010 | 08:14 PM
TheShodan's Avatar
Moderator
Default Re: d16a1 dohc questions!!
Uh oh......... It begins
Old Jul 29, 2010 | 08:18 PM
sjp00422's Avatar
Old Jul 29, 2010 | 08:59 PM
boostedeg302's Avatar
whoa dude a dual cam d16..that must be super jdm!!!
Old Jul 30, 2010 | 05:28 AM
netfreak's Avatar
The second cam is taped to the valve cover
Old Jul 30, 2010 | 10:00 AM
95civhb's Avatar
Of course he or she means DOHC ZC... give the benefit of the doubt
Old Jul 30, 2010 | 10:24 AM
riceburner700's Avatar
d16a1s are a dohc almost identical to the dohc zc
# Displacement : 1,590 cc (97 cu in)
# Bore and Stroke : 75 × 90 mm (3.0 × 3.5 in)
# Valvetrain : DOHC (4 valves per cylinder)
# Fuel Control : OBD-0 MPFI
# 1986-1987
* Compression : 9.3:1
* Power : 113 hp (84.3 kW, 115 ps) @ 6250 rpm
* Torque : 99 ft·lbf (13.7 kg/m, 134 Nm) @ 5500 rpm
* Piston Code: PG6
Old Aug 28, 2010 | 10:11 AM
staticchmbr's Avatar
the D16a1 WAS A DUAL CAM that came in 86-89 integras, but do share many parts with the dohc zc.. read up before you flame guys..
the 86-87 d16a1 came with about 9.2:1 and the 88-89 d16a1 came with about 9.5:1. the 86-87 d16a1 will be harder to turbo due to the vacuum advance. the 88-89 d16a1 came electronic advance, and shares the same type of wiring as other obd-0 cars. i had mine anywhere between 7-10PSI with a .48 (hot) .60 (cold) turbo from a ford. you have to do it right though, or it will blow up
Old Aug 28, 2010 | 08:47 PM
QUICK8CIVIC's Avatar
lesson learned: when in doubt,Google first before posting..
91'ZC boosted
Jun 17, 2009 02:09 PM
gnccracer20
25
Feb 11, 2009 01:23 PM
1point7db2
Jul 17, 2005 11:12 AM
teamols
Jun 5, 2005 07:11 PM
Gant
10
Apr 29, 2004 05:26 PM
