Brake Bleeding tubing.......
....does anyone know what diameter to buy at the Home Depot....i am going there after work and I can't remeber.....plus I am too lazy to drive all the way home and measure my bleed screw
thanks
thanks
I just bled my brakes for the first time. I bought 5/16" and 3/8" tubing (I think each was under 20 cents/foot at the hardware store). The 3/8" felt right going on, but was too loose to seal. The 5/16" worked OK. Eventually it started leaking a little; it helps if you cut a little off the end between wheels, since the tubing will stretch a little. Next time I might try 1/4" to see if I can get it over the bleeder.
what you do is buy the smaller one and just heat it up with a lighter and then it will mold itself to fit on the bleeder. then it shouldn't leak at all. good luck
Another good way that I have found works is get if you have one of your vaccum lines laying around and cut a little piece of it. Being itself ruber it seals right everytime.
Rado
Rado
Maybe it's what you're talking about, but I really like the very rubbery tubing for brake bleeding. I'm not sure how to describe it, but hobby stores sell it as gas line for R/C stuff. It will stretch to fit anything from a small Wilwood bleeder, to a standard honda bleeder with no problems.
DailyDrivenDB8
Suspension & Brakes
20
Oct 27, 2008 06:01 PM
