only one fan working help please!!
hey everyone i have a 89 accord and when we first got it neither of the fans worked.. but my dad somehow took two wires from the fan and put them together and now the passenger side fan works and keeps my car pretty cool! i just really wanna get the other fan working just so it stays extra cool if anyone could help that would be great thanks!!
We know the one rad fan motor (engine cooling-right/pass side) is good, it is wired somehow and it works. Does it run all the time or cycle on and off as the temp gauge goes up. If not, there are testing procedures for finding out why it is not working as it should (switch, fuse, relay, ect).
PS-The left/drivers side fan is called the condersor fan motor (it shoud be a 4 cyl?)
it runs when the engine is on and when i shut it off until it cools down so it keeps my engine at a good temperature i just really wanna get the other one working too.
on my 91, the fan on the left (looking under hood from front) is the cooling fan. the one on the right is for the A/C only. it never comes on if you arent running the a/c.
is your car throwing any codes? coolant temp sensor maybe?
that should fix it. the CTS tells the computer how hot the coolant is, and when the fan needs to run. w/o it, it just never runs.
personally, i dont see why they dont wire them so that they open short when the sensor dies, causing the fan to never STOP running. maybe in cold regions that would be a problem, but at least then as person could just unplug it for the winter, instead of risking heat damage if the malfunction occurs in the summer.
anyway, if that doesnt fix it, you might want to check the wiring harness for breaks or melts. dont forget to reset the computer after installing the new sensor.
to be honest, im not real sure on your model. on pretty much any car though, you can pull the battery terminals and let it set for ~5 min. there is usually a fuse that you can pull that will do the same thing w/o unhooking the battery and resetting your clock, radio, etc. try searching the forum to see if you can find out the fuse method, if you care.
it should go w/o saying, but also make sure your dad undoes whatever he did in there before you hook everything back up.
for future reference, any time the car is not running right, or something on it isnt working, the first thing you want to do is check for engine codes. a lot of the time a sensor is to blame. if you ever run into a sensor code, but replacing it doesnt fix the problem, check the wires. a short is the same as a bad sensor to the computer. also, do yourself a favor, if you havent already, and spend $20 for a haynes manual for the car. it will walk you through most of the basics. or you can search online for an actual service manual instead, which will have much better diagrams and instructions.
elliascool
Jul 18, 2011 03:02 PM
