need some answers
1-what do you look for on a cam to show proof its a CTR cam like a code number?
2-what are some things to look for if head is no good?
3- what are some thing to look for if a block is no good?
4- what are the most legit thing to put on a ls vtech to make it reliable?
5- What do recommend when building a LS/Vtech motor.
6- Is LS block the best?
7- Whats pistons are the best and what cams are the best for major power?
1: the code # will be 443ctr655
2: if the ports are a mirror image than its no good
3: press on the cylinder wall, if you see your tumb print its no good
4: ls/gs water pump
5: synthetic vtec crank oil from honda dealer
6: yes ls block can withstand 2x more pressura than any other honda block
7: b20z cams and pistons
I have more questions now?
1-what is the best piston to buy for good hp but also daily driver hows 12.1 comp?
2- More details on how to tell if a b16 head is good.
3-more details on how to tell if a block is good?
Im new to checking motor parts thanks for who helps me out it makes hondatech look good!
Everybody has questions and everybody had answers. THANKs
#1ekboy
Jul 29, 2010 06:17 PM
