power window on the passenger side is not working!!!
ok dumb question... how do i do that? use a 12v battery like ur testing christmas lights? i know i fail. i just wanna make sure i don't fukk anything up.
I use a cordless drill battery. FYI: If you have to go to the junkyard it's usually the only kind they allow.
ok lemme get this straight.
i'm unplugging the 2 pin connector. then i use a 12v battery, connect 2 wires (+ and -) from the battery and connect that to one connector.... and then connect the other connector with one wire and ground it?
"2 pin connector"
connector 1 connector 2
12v + - ....... ground
"2 pin connector"
Dude.. seriously..
You're only going to be putting power to the wires that are connected directly to the power window motor.
Yes, + to one terminal and - to the other on the same connector attached to the end of the wires coming directly from the power window motor.
si_motor_spt
Honda Civic (2001 - 2005)
14
Jul 12, 2010 01:37 PM
4drint3gr4
Mar 16, 2009 02:21 PM
_Bug_
Nov 29, 2006 03:48 PM
