my car wont start or even turnover
So my friend drove to mcdonalds to get food and was getting on it and miss 3rd and hit 1st, the car died and didn't turn back on....i need help...this is my only car...did i fry the ecu??????/
Check your relays and fuses first. Make sure the fuel pump turns on and that you have fuel pressure. You'll need to find which system isn't working. Try checking your valve timing. You might borrow a noid light set from a parts store and verify that the injectors are firing. Make sure you're getting spark. Avoid turning the motor over until you know what's going on, if possible.
Ive seen multiple people miss gears completely trash their valves. Hopefully thats not that case but you could be looking at a complete topend rebuild...
So he missed 3rd and went to 1st instead and over-revved the engine? I've heard of a few people destroying engines this way. I would take it to a mechanic if you arent comfortable diagnosing it yourself.
So he did a 1-2-1 shift? If so then your valves bent and possibly dropped. Your motor said bye bye.
Check this out-http://www.youtube.com/watch?v=gLAGw_V2jxM
toytroy
Sep 27, 2012 10:06 AM
is3oo
Sep 8, 2008 01:07 AM
