Acura/Honda B16/B18/H22/VTEC Valve Spring Compressor
This Valve Spring Tool for the Acura/Honda B16 Vtec, B18C1/B18C5 Vtec, H22 Vtec
The Valve Spring Compressor is CNC Machined, Anodized Blue, Laser engraved and made in USA.
This tool makes it easy to replace valve seals, valves, springs, and retainers. The tool is attached to the head with 2 short bolts. Once the tool is attached to the head you put a retainer cap (comes with kit) on the retainer/spring(s) you want change next you tighten a bolt that will push down on the retainer allowing you to easily remove the keepers. Next simply UN-tighten the bolt and remove the retainer cap to remove the spring(s).
You can use this tool with the head on the block.
Kit includes:
Valve Spring Tool
Retainer cap
Two bolts
One long bolt
Magnetic Screwdriver
here is a link to our website showing the product being used.
http://www.euroexportinc.com/store/t...ompressor.html
Kit includes:
Valve Spring Tool
Retainer cap
Two bolts
One long bolt
HPTautosport
Performance
55
Mar 19, 2017 10:14 AM
Golding.racing
Dec 14, 2011 10:42 AM
turbojdmsol
Jul 4, 2011 03:29 PM
boostd92
Oct 7, 2008 04:56 PM
