Cheap Axles pulling out
Old Jul 27, 2010 | 07:02 PM
Rishiras's Avatar
Default Cheap Axles pulling out
Guys,
I have bought those $88 axles on ebay for my Ek9 with ITR 99 SPEC engine,
I have noticed twice now, the RIGHT SIde AXLE pulls a bit out of tranny and leaks the oil out messing the complete underside of the car.
Anyone suggesting what this might be?
I am thinking the quality of those cheap axles are more for less powered engines , I am considering buying 2 new tranny axles seals and 2 hasport stage 1 axles .
let me know your opinion.
R
Old Jul 27, 2010 | 07:12 PM
tacosandbeans's Avatar
Default Re: Cheap Axles pulling out
Probably the axles are to short. If you're slammed to the ground you might want to raise your car to stock height that will make the axles in less of a bind. The best idea was to either buy oem b series axles or some from DSS or hasport.
Old Jul 27, 2010 | 07:27 PM
TUR3Ovtec's Avatar
change the axle seals. you should of changed them when you put in the new axles just in case. they r cheap just go get some oem ones.
Old Jul 28, 2010 | 03:47 AM
Rishiras's Avatar
Yes, car is lowered with CUSCO coilovers set Zero-2.
I ordered the 2 new oem seals and willl get me some hasport stage 1 axles.
Thanks guys,
R
Old Jul 28, 2010 | 04:04 AM
Nichelson_Performance's Avatar
Axles being short is my guess too which is typical ebay
I run new stock replacement axles in my built d16 turbo on 20psi with no power related issues and these are advance auto axles....my car is also lowered hard about a little over 3 inches
Old Jul 29, 2010 | 07:34 PM
Rishiras's Avatar
thanks guys, i ordered new oem tranny Seals and will get me a set of hasport axles.
Any model # from hasport recommended ? my car is a JDM Ek9 with ITR 99 spec engine+tranny S80
Wheels are 16" JDM ITR wheels.
R
Old Jul 30, 2010 | 10:51 AM
Hasport's Avatar
the Hasport axles you need would part # EGBAX
we do have a dealer in the Netherlands as well 12tune
Old Oct 1, 2010 | 04:46 AM
Rishiras's Avatar
Guys,I got the EGBAX hasport axles, they work excellent, what i have been noticing is that after some races the right side axle (hasport axle) still pops out,what would cause this to happen?
R
Old Nov 9, 2010 | 01:58 PM
bujeezus's Avatar
if that's yer idea of them workin excellently, i'd wonder what your idea of shitty would be?
Old Nov 9, 2010 | 02:01 PM
jdmh22eg2's Avatar
diff is prob done if it is not locking in like it should
Old Nov 9, 2010 | 02:03 PM
bujeezus's Avatar
R
did you replace the lock ring with a new one or just reuse the old ones?
Old Nov 9, 2010 | 03:43 PM
Colin00's Avatar
I know this guy personally who sells these axles (no, Im not him, rest assured), and unless youre running a Rb26DETT or something, these axles are fine.
He's used them in his Boosted b18 em1, and boosted itr and nothing's happened yet
boostedb20ek
Transmission & Drivetrain
Apr 23, 2024 08:58 PM
thatnikkashoD
Oct 25, 2011 12:08 PM
Rishiras
Feb 1, 2005 02:47 PM
TypeRod
Aug 21, 2002 10:48 PM
John
May 13, 2002 11:25 AM
