need alittle help 94 civic auto no start
Old Jul 27, 2010 | 05:25 PM
civicracer94's Avatar
Default need alittle help 94 civic auto no start
ok so my buddy has a 94 civic 4 door ex (z6) he bought this car cheap someone had swapped the motor but didnt finish it so thats where i come in .. ok got everthing done and car ran good no CEL nothing .. ok so heres where the problem is about 1 out of 5 times it will not start ... when it dont i didnt hear the fuel pump... i changed that still the same thing ... ok then i checked for fire and when it dont start its does still fire ... then i realized i didnt hear the injectors workin or spayin.. so i changed the main relay... and again samething ... so i thought the only thing left is the ignition switch... so i thought.. changed that today and still the same thing .... any ideals ???
Old Jul 27, 2010 | 05:43 PM
Former User's Avatar
Default Re: need alittle help 94 civic auto no start
Check the fuel pump and its power and ground wires.
Old Jul 27, 2010 | 05:45 PM
the pump is new ... and tracked down all the wires... do u think the ecu could cause this ?
Old Jul 27, 2010 | 05:50 PM
A bad ECU is possible. Or even a bad wire between the ECU and main relay.
When the fuel pump won't prime and the engine won't start, does the CEL remain on steady with the key in ON(II)? If so, have you tried to pull the CEL code?
Old Jul 27, 2010 | 05:56 PM
no.. no codes at all .. you can keep turnning the key on and off and after a few mins the pump will come on and it will start .. but like i said it does still fire .. so i ran a hotwire to the pump .. and still wouldnt start ( the injectors wasnt spaying )
Old Jul 27, 2010 | 08:06 PM
Does the CEL work?
Old Jul 28, 2010 | 03:14 AM
Does the CEL work?
yes it does work
Old Jul 28, 2010 | 06:33 AM
Check whether dash fuse 24 (ACG) is loose.
Check the wire running between the main relay and ECU A23/A24.
Swap in a known good ECU.
Old Jul 28, 2010 | 07:45 AM
apexi_rsx's Avatar
main relay under the dash
Old Aug 17, 2010 | 04:03 PM
ok new dizzy,ignition switch,main relay,fuel pump .... anyone ??
Old Aug 17, 2010 | 04:20 PM
It's get quite expensive replacing parts at random. A good multimeter only costs $10-$25. A lot less than what you have spent already.
Old Aug 17, 2010 | 04:28 PM
95EG2's Avatar
Since u don't hear the fuel pump prime it either one of two things: the fuel pump or MAIN RELAY... since fuel pumps never go bad on Honda's... IT THE MAIN RELAY!!!
Old Aug 17, 2010 | 04:32 PM
You guys need to read post #1 and #10.
Old Aug 17, 2010 | 04:43 PM
yeah i changed it .. and 5th gens dont have a fuel pump relay only main ralay
Old Aug 17, 2010 | 04:45 PM
yes i know but he works at autozone so we get to try out all kinds of parts
kish2554
29
Dec 11, 2013 09:12 PM
alex801to410
Oct 12, 2012 01:41 PM
GregB
Jun 14, 2012 02:48 PM
NortesidinII
11
Oct 26, 2010 03:46 PM
cueto
Jun 15, 2009 07:37 AM
