how to check wat engine
Old Jul 27, 2010 | 04:42 PM
Beto760's Avatar
Default how to check wat engine
Hey jus had a quick question i have a 95 honda civic dx with a d15 engine but i was woundering if there is a way to check what exact engine for example ( D15a or D15b) would appriciate the help thx
Old Jul 27, 2010 | 04:46 PM
Hill4589's Avatar
Default Re: how to check wat engine
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
Old Jul 27, 2010 | 05:13 PM
Syndacate's Avatar
@ OP:
Yes, always check the FAQ, first.
Though since it's kind of a mess right now (I'm in the process of rebuilding it), I'll point you in the right direction.
There's OEM engine codes here:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/chassis-code-cheat-sheet-other-specs-too-2581875/
And here:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/honda-motor-codes-2105704/
As for where to find the engine code on your engine (ie. you're not sure if it's the original engine), I'm not sure if there's anything in the FAQ about that (though there should be, it's asked all the time, maybe I'll do a write-up on that if I can't find one :-?), so I'll straight up tell you: When looking at your car from the front, look to the left of the header, and follow the side of the engine down (still looking from the front) until just above where it meets the transmission, there's a block there and the engine code is cut into it. It might be a bit dirty, though is fairly obvious.
Heybeyotch
Feb 25, 2013 11:26 AM
SpeedRacer00-667
Nov 9, 2002 11:24 PM
