cam gears and pully
are obx cam gears quality (5 bolts)?
how long for cam gear install?
how long for pully install?
under$400 for both..... is it worth it?
used v-afc $150?..... worth it?
thanks for the help.
Get good cam gears if you take the time to replace them. I would't trust OBX internal components.
Pully install is a pain if you don't have the correct tools. Also, get an unorthodox pulley if you buy any, because you can be assured of the quality and balancing of the piece. Most all of the crank pulley failures you hear about are because of generic pulleys. Some are even cast aluminum cheapos!
