PCT's in a built GSR motor, Pro 2's too big?
Old Jul 27, 2010 | 10:18 AM
Nerologic's Avatar
Default PCT's in a built GSR motor, Pro 2's too big?
I am wondering about piston to valve clearance.
Too lazy to clay the motor, anyone ever run big cams inside a GSR with CTR's??
Thanks in advance!
Old Jul 27, 2010 | 10:33 AM
kyden's Avatar
Default Re: PCT's in a built GSR motor, Pro 2's too big?
if you're too lazy to clay, we're too lazy to tell you.
Old Jul 27, 2010 | 12:14 PM
Nerologic's Avatar
If the motor wasn't inside the car already I would have never even bothered to make this thread.
Unfortunately the swap is in a car and is a daily driver, hence the reason why I made this thread.
Old Jul 27, 2010 | 12:25 PM
DDTECH's Avatar
Usually with pro series cams, p2v isn't really a problem per say..
its normally a v2v problem.. there have been motors running ctr pistons and have had no issues, again i ask why someone would run CTR pistons in a gsr in the first place.. but thats neither here nor there..
You shouldn't have any issues, keep a 4 degree of separation
If your using standard gears which are 1 degree = 2 crank degrees go +2 exhaust / 0 on the intake
If your using the more precision style of gearing like GE or pro series does now, you'll wanna use +4 exhaust and 0 on the intake.
Old Jul 27, 2010 | 12:29 PM
Nerologic's Avatar
Thanks for the input, just wanted to make sure before I put them in and do a retune.
The motor unfortunately already had the CTR's to begin with, so I am just working with the card i was dealt lol
Thanks again...
Old Jul 27, 2010 | 12:31 PM
DDTECH's Avatar
Thanks again...
Not a problem.. again.. i dont think there's any p2v problems.
Make sure your running a 3layer hg.. and i'd run a step colder plugs too i 'd go to 8's, if it were me.
Old Jul 27, 2010 | 12:56 PM
3s1k's Avatar
I'm using BC spec 4's with PCT Pistons in my C5 with no problems. Not my choice of pistons but I bought the car with them installed already.
Old Jul 27, 2010 | 01:48 PM
CONTROLLED CONFUSION's Avatar
you can clay with the engine in the ca.r wtf is wrong with you?
Old Jul 27, 2010 | 03:46 PM
Nerologic's Avatar
Too much stuff going on in my life to rip off the head, intake manifold, header etc ect
And I'm not about to pay someone to mess with the car lol
Old Jul 27, 2010 | 03:47 PM
Nerologic's Avatar
C5's have more clearance.
Old Jul 28, 2010 | 09:32 AM
SonicB's Avatar
The biggest problem you are likely to experience is piston to head clearance, as the CTR pistons have a timing edge (quench pads) that extend above the block deck. This will dimenish the engine's piston to head clearance to about .025", which is insufficient. You can cure the problem by using a .036" head gasket, but on non milded head.
Check your piston to valve and valve to valve clearance prior to running the engine to insure that it's sufficient.
My recommendation: Get a new pistons. CP's, wiseco's... they are half the size of those heavy PCT and have big deep valve pockets for most extreme cams and can take much more power abuse
Old Aug 12, 2010 | 03:30 PM
Nerologic's Avatar
Piston to head is fine.
Everything worked out with out any issues.
Old Aug 12, 2010 | 03:40 PM
gqseller's Avatar
impresstive
Old Aug 12, 2010 | 06:50 PM
tales sol's Avatar
good for u!
now, more importantly...... how does it run???
u got it tuned?
Old Aug 13, 2010 | 10:32 AM
Nerologic's Avatar
Not tuned running the same tune that it had with ITR cams.
Runs decent, for what it is...
Old Aug 13, 2010 | 10:45 AM
atec's Avatar
I can promise you one thing, if the valves hit each other and one or more valves drop, you will hate yourself for needing to buy a totally new engine and not take 3-4hurs of your life to check..
head on and off take you 3-4 hours to perform if you know what you are doing. and I promise you it is worth the hassle to KNOW that the valves do not hit, you will also be able to play a little around with the cams on the dyno without worrying.
Even If the valve get slightly bend by a small hit (to narrow clearence and a modest valvefloat at high rpm) you even dont know it has happened until you cruice down the road and your engine suddenly stops, pull a plug and it looks like it has been chewed by a mad "steel" piraya.
Clay you motor, be sure, dont guess, and you will feel SO MUCH BETTER!
Old Aug 13, 2010 | 11:04 PM
koczeka's Avatar
I daily drive pcts with Toda C-s set at +2,0 to over 9K... it was clayed and its OK.
nitroeg
Jul 30, 2005 11:20 AM
jeremy.
199
Dec 23, 2004 03:45 PM
ScottFern
12
Sep 25, 2003 01:58 PM
akhom
Oct 13, 2002 07:58 PM
stretracr
Jun 26, 2001 06:16 PM
