ITR trailing arms prob!!! pls Help!!!
My idiot friend just wrecked his ITR and bent the rear trailing arms on the passenger side. I was wondering if anyone had any advice or websites we could check. also if a standard integra rs, or gsr would suffice.
A trailing arm off another integra will not work.
Order from here, It's basically $216 shipped per side.
Input 52370ST7R02 into the blank space in the part number search option
http://www.trademotion.com/partlocat...&siteid=214999
you can use any 94+ integra trailing arm. you just have to take off the entire hub assy and swap it out onto a non-bent trailing arm. even a 92+ civic will work
on a side note though you may have damaged the hub bearing and that I would suggest getting new
DC2-ProdUcTiOnS
Jun 24, 2017 07:24 PM
bgod
Sep 26, 2004 04:32 PM
