new to CD5
Old Jul 27, 2010 | 07:39 AM
c_dioxide's Avatar
Default new to CD5
quick question, I'm picking up a 94 ex in a couple weeks and I have to drive it 2,000 miles within 2 days and was wondering if there was anything I should replace before I make the drive? The motor/body both have 122,000 miles on it, and the guy told me he changed the front rotors last week because they were going bad and also put new tires on it. belts/hoses/etc? as far as I know, he has not had tune up within the last 20,000 miles. thanks
Old Jul 27, 2010 | 07:45 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: new to CD5
has the timing belt ever been replaced?
Old Jul 27, 2010 | 07:50 AM
c_dioxide's Avatar
I have no clue, it's hard to contact the guy because I am still in Iraq. But I will be able to find out in about 5 days. Money is not an issue for replacing parts or tune-ups, got the car for a good price. thanks
Old Jul 27, 2010 | 10:38 AM
Just1nK4ng's Avatar
this is what i did with my accord ex coupe 94 replace cap, rotor, sparkwire, spark plugs. also did a eco tuning, replaced airfilter, replaced gas injectors, and tires inflated to the proper pressure.
if your timing belt is messed up or getting old change that plus your hose.
Old Jul 27, 2010 | 11:24 AM
TheMuffinMan's Avatar
He knows where you live!
So essentially, you did very very basic maintenance
With the amount of miles the OP is looking at and age of parts, and having no idea when parts were replaced a FULL tune up is necessary to play it safe. Especially if driving it 2000 miles.
- fluids (brake/ps/tranny/engine/coolant/etc)
- tbelt/water pump
- brakes/rotors
- belts
- plugs/wires
- filter
Old Jul 27, 2010 | 11:28 AM
c_dioxide's Avatar
thanks guys, I will definately get this done.
Old Jul 27, 2010 | 11:32 AM
And with that, the CD5 isn't necessarily any different than any other Honda in regards to maintenance.
Timing Belt/Water Pump (major service) is like 80-90k or 7 years. A 94 Accord is 16 years old at this point and needs both done because of age, and not mileage.
Same with most other things, brake fluid attracts water over time, that can rust out lines and f up your braking. Best to change that out.
Tranny fluid doesn't do you any good if it's old and burnt up as ****.
etc
Old Jul 27, 2010 | 12:01 PM
c_dioxide's Avatar
another question: I want to make roughly 250hp na, is that reasonable with an h22a? or should I just rebuild the f and boost it if I want to increase?
jmk64
19
Oct 19, 2010 05:05 AM
Tmac06
Jul 3, 2009 11:58 PM
joychri
Mar 19, 2008 07:29 AM
j6shin
Jan 20, 2008 05:33 PM
turbod16y7vtec
Jul 14, 2002 05:08 AM
