Codes 1,8,16 on 91 civic DPFI
Old Jul 26, 2010 | 07:19 PM
fijisac's Avatar
Default Codes 1,8,16 on 91 civic DPFI
ok so i started my car today and it ran like crap. the second i would try to accelerate the car would die. so i pushed it back home (only 3 blocks away from home and didn't want to waste money on a tow). Tried to start it and it starts up but i got these 3 codes. Code 1,8,16. Code one is an oxygen sensor which i replaced two days ago. Code 8, which is TDC / crank sensor. and finally the epic code 16, injectors. If i try to rev up the engine, it will die but if i only softly hold the gas pedal then it will rev up. Also if i let the car roll on its own in drive, it will go up to like 15-25 mph and then die. The car is a 91 Civic sedan with a D15b2 Dpfi. Can someone please help me out cause i don't know what to do anymore.
Old Jul 26, 2010 | 08:19 PM
elmalouno's Avatar
Default Re: Codes 1,8,16 on 91 civic DPFI
give more info about the car. its a 91 dx?auto or 5spd? stock?
Old Jul 26, 2010 | 08:21 PM
fijisac's Avatar
91 dx automatic and its bone stock with 149K miles
Old Jul 26, 2010 | 08:23 PM
elmalouno's Avatar
have you had issues with the car before today or was it running well until today?
Old Jul 26, 2010 | 08:33 PM
fijisac's Avatar
nope, it was running fine until today but i did get that code one a week ago so i just switch out the oxygen sensor
Old Sep 21, 2010 | 10:25 AM
christiancivic's Avatar
Icon3 Re: Codes 1,8,16 on 91 civic DPFI
I am having the same problems with my 91 civic hatch. I have the D15 dpfi. Its a 5 speed, has no cat, has an after market msd ignition system, cold air intake, and hand made exhaust. I just resently replaced the fuel pump and filter. The injector ohm out within specs. I believe the o2 sensor is shot. Want to know if anyone has any ideas or maybe has had the same problem.
Old Apr 16, 2011 | 08:53 AM
kris95dx's Avatar
same issue here too, just happened last night. i have the same car 91 crx dx auto, codes 1, 8, 16. Can't press the gas too much or it bogs. I think the dizzy needs to be replaced, but im also thinking the timing belt might be an issue too, mine has a ton of deflection anyway
FuNkDrSpOt
Mar 24, 2007 01:22 AM
high_octane
Mar 8, 2007 03:13 PM
curioso
Nov 21, 2006 06:48 AM
Mr. Vapor
Nov 19, 2002 02:03 PM
