what ets and mph? please give your opinion
Old Jul 26, 2010 | 05:29 PM
lsvtechatch92's Avatar
Default what ets and mph? please give your opinion
so if you have a car that weighs around 2450 or so with driver what should the car trap with 450whp give or take a few whp... and what should the et and or trap be with 570 to600whp? thanks in advance guys this is on 24.5 slicks with gsr tranny
Old Jul 26, 2010 | 06:17 PM
boostedeg6-1's Avatar
Default Re: what ets and mph? please give your opinion
I personally went 10.44@140 weighing 2520 with driver making right at 575-580whp!, B16 trans with an ls 4.266 final! But its all gonna depend on how well you drive the car! I had a 1.61 60ft! But making the 570-600 you could go 10.20's at around 140ish traps.!. All depends on your driving and how the cars setup! Good luck with it.
Old Jul 26, 2010 | 06:20 PM
that would be awesome... i cant get my car too boost correctly with the boost by gear!!!! did you run that with boost by gear or with a manual boost controller
Old Jul 26, 2010 | 06:24 PM
Hondata s300. Wastegate spring in 1st and 2nd gear which was a 1 bar spring, then 18-19psi in 3rd and 4th gear!
Old Jul 26, 2010 | 06:32 PM
i have a 9 psi spring ... i honestly dont think it will build much more than that in first... i had it set up on boost by gear but it would never boost how i wanted it to or ramp like it should... who knows it seems like i cant get any help as far as getting it set up right....
Old Jul 26, 2010 | 07:23 PM
bads2k's Avatar
I went 10.3 @ 136mph on my old setup at about 2350lbs making 500whp. my new setup made 630 on 23 psi went 10.2 @ 139. 15-16psi in 1st and 2nd and 21 psi 3rd and 4th gear. new weight is around 2400lbs.
Did you setup the boost by gear duty cycles on the dyno? what are you having troubles with?
Old Jul 26, 2010 | 07:27 PM
pmed you
Old Jul 27, 2010 | 08:15 AM
pellis90's Avatar
Who Knows, all depends on if you know what the hell your doing. Take it down the track and then post. Key board racing sucks.
Old Jul 27, 2010 | 09:16 AM
tony1's Avatar
Marcus, if you'd get me the info I asked for I could help you figure it out, but i'm not going to waste my time trying to figure out your car if you can't give me what i'm asking for. Besides the fact that your wastgate setup sucks and boost creeps, which makes dialing in boost control a lot more difficult.
Old Jul 27, 2010 | 09:53 AM
I went out and made 10 logs I sent 4 to you after. I sent you that one whetther you got them or not is beyond me. What exactly do you need and I will get it asap
Old Jul 27, 2010 | 10:03 AM
tony1's Avatar
Not that it matters, but this was my last email to you and I never got a reply.
Old Jul 27, 2010 | 07:43 PM
mikesrex's Avatar
I've offered to help Marcus get his boost controller set up correcly but he has never taken me up on the offer. Better yet we both live in the same town.
The controller setup is pretty simple compared to some of the stuff I have dealt with in the engineering world.
Old Jul 28, 2010 | 04:53 PM
i dont recall you EVER trying to help me with it
JBLAZE622
Jun 21, 2008 08:00 AM
CoreyR
Aug 16, 2007 07:58 PM
Griffin@Camtech
May 13, 2004 05:18 PM
Griffin@Camtech
Mar 3, 2004 05:17 AM
brega3
Jun 26, 2003 10:05 AM
