Why is antifreeze coming out my intake manifold?
When i hit the gas antifreeze comes out my intake manifold. Do i have the hoses on the back swapped around? (on the housing for the radiator house)
if anything is wrong with the intake manifold gasket it'll seem through as well.
check to make sure the nuts are tightened
just loop it and dont use coolant to your TB.. If you live in snowy conditions,then youll prob need it to warm the TB and keep it from sticking.
by looping it you mean loop it from where it comes out the thermostat housing and loops to the intake manifold and put it on the thermostat part of the housing that goes to the firewall (making the thermostat loop to itself) ??? so that it basically bypasses going to the firewall or intake/throttle body
Integacivic
Jul 31, 2004 01:59 PM
