Suspension & Brakes Theory, alignment, spring rates....
Needing ADVICE, subframe tearout recovery.
Old Jul 26, 2010 | 06:47 AM
EH3Civic's Avatar
Default Needing ADVICE, subframe tearout recovery.
So, I've had this 1994 civic si for 9 years, and we've been through a lot over the years. Well, I had a moderately to low aggressive suspension setup (tein superstreets, spoon strut bars, and srr swaybar kit with tiebar and reinforcement). The car drove great with this setup UNTIL the holes in the subframe that held on the reinforcement toreout. Since then, the car sways and rolls in turns like you'd expect, as I had to remove the sway bar and reinforcement stuff.
I'm now wanting to return to the days of stiff cornerning and that means adding a sway bar once again, and reinforcement. Now, the fix that I performed when it tore out last time was I brushed off all the dirt, I hammered the ripped metal back in to normal, and I welded sheet metal over the holes. I know the ASR brace requires drilling out the welded nuts anyways, so do you think it would be disasterous for me to just drill holes where needed on mine and use an asr brace? Thanks in advance.
Old Jul 27, 2010 | 04:32 AM
EH3Civic's Avatar
Default Re: Needing ADVICE, subframe tearout recovery.
No one??
Old Jul 29, 2010 | 08:12 AM
alphalanos's Avatar
Might as well. Best case it works fine. Worst case it tears again and you just have to get it rewelded, or get a new subframe welded on.
Old Aug 15, 2010 | 07:23 PM
JHMEG8's Avatar
I have the same problem, just found out today. I have a '94 Civic sedan. Will be removing blox 21mm sway tomorrow.
Mo_Spec
Jan 17, 2012 04:17 PM
MoE JdM
Aug 5, 2007 09:09 AM
Maxboost00
Suspension & Brakes
May 17, 2006 08:46 PM
dtrtw
Feb 13, 2005 10:53 AM
93SSPHatch
May 24, 2002 08:41 AM
