95 Accord Questions
Old Jul 26, 2010 | 05:48 AM
H22Shifter's Avatar
Default 95 Accord Questions
Hello All, I recently acquired a 95 Accord with a H22 full swap. Just replaced all gaskets in the engine and eliminated all leaks, while replacing a lot of stuff and converting my tensioner. I also replaced an axle and got her running to perfection. But, I have a few questions about the car, and I am new to the Honda world. As follows:
- My Vtec kicks in a 3800, why is that
- I have a squeak from the passenger from wheel area, AS WELL as some hopping and a pop pop pop noise, kinda like my strut is fubared
- I just bought some Nuespeed springs and they are already mounted on a new set of struts, I really want to put them on the car, because my current struts and springs are bottoming out on even the smallest of bumps. I have 18x7.5 te-37s on the car and i am just curious if i am going to have any clearence issues??
- The car has 181,500 on the body and 45k on the swap. Below are some pictures, any input is greatly appreciated. Thanks guys!!!
Old Jul 26, 2010 | 08:56 AM
sgraham01's Avatar
Default Re: 95 Accord Questions
as far as the squeak goes, there was a Honda recall way back when for the front bumpstops. they supposedly stick to the strut shafts and squeak when you enter steep driveways and the like. I replaced mine when I did my drop and i'm pretty sure it stopped. at least i haven't noticed it anymore. i think the recall part number is the same as the original part number, but just an updated material. i can send you the recall part number if you really want it. PM me.
Old Jul 26, 2010 | 09:14 AM
H22Shifter's Avatar
Ok cool, well I have new struts and shocks also that will be going on with my springs
Old Jul 26, 2010 | 09:20 AM
sgraham01's Avatar
you should probably go ahead and change the bumpstops while you're at it if you think are are having that problem. Mine would do it each time i turned into my driveway (one wheel going up and the other going down)
Old Jul 26, 2010 | 09:21 AM
H22Shifter's Avatar
do you have the part number?
H22Shifter's Avatar
and do you forsee me having any clearence issues?
Old Jul 26, 2010 | 09:39 AM
sgraham01's Avatar
I can get you the part number tonight or tomorrow when I can get to my TSB's. I think it's the same number as the original. you can find it on hondapartsnow.com. i'll try to get the number tonight.
i have stock 17x7 RSX wheels with a 45 mm offset and I don't rub at all, ever. With 17.5, you might, but I can't say for sure. your wheel travel won't change with the drop, but if you are lowering it more than 1.5", you may rub at low speed full turns.
Old Jul 26, 2010 | 06:26 PM
sgraham01's Avatar
part number for ONE new front bumpstop is 51722-SV4-902, order 2, about $10 each i think.
Old Jul 26, 2010 | 11:50 PM
JoeBull's Avatar
Which one is the original and which one is the replacement? 51722-SV4-902, 51722-SV1-A12. They are both rubber 51722-SV4-901 is polyurethane. I am doing my front end and figured the bump stops would be good. I didn'nt know about the recall. Thanks, but need more info.
Old Jul 27, 2010 | 07:56 AM
H22Shifter's Avatar
Yeah which one is the correct one, I saw on hondapartsnow.com that a12 is the replacement for 902. anyone?
Old Jul 27, 2010 | 04:44 PM
nus_dogg's Avatar
What ECU are you running? JDM P13? Chipped P72 or P28 chipped ECU?
As for your VTEC engagement, you can get a chipped ECU and have your local tuner set it to 4.5K or 5.3K rpm for to VTEC to engage. 3.8K is a little to low for VTEC.
Old Jul 28, 2010 | 04:10 AM
H22Shifter's Avatar
I would think it is a USDM p13, i do not think it is chipped, and why is it engaging at 3800k
Old Jul 28, 2010 | 08:16 AM
sgraham01's Avatar
51722-SV4-902 is the number listed on the original Technical Service Bulletin from sometime back in '95 or '96. HPN is showing it as replaced by 51722-SV1-A12. Go with that. Must have been updated. I can't remember what the number was on the actual packaging when I got them, but it may have been SV1-A12.
Knth Wong
Jun 20, 2019 07:39 AM
Fighttjk
Jun 23, 2018 09:18 AM
acc89
Jul 12, 2007 06:45 PM
