kind of a stupid question ... h22 oversized valves with skunk2 stg 2's
Old Jul 25, 2010 | 11:42 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default kind of a stupid question ... h22 oversized valves with skunk2 stg 2's
I know the real answer is that I need to pull the head and check v2v clearance but I was wondering if any one else has ran blox b's or skunk2 tuner 2's with .5mm oversize valves?
I have adjustable cam gears and I wanna throw these cams in and get tuned as soon as I can..
Old Jul 26, 2010 | 07:09 AM
EdSales's Avatar
Default Re: kind of a stupid question ... h22 oversized valves with skunk2 stg 2's
On the Skunk2 Website, the recommend not using the Oversized Valves with there Stage 3 and Stage 4 Cam Shafts. With that said, I would assume Stage 2 would be ok, but will sit in and wait for someone with more knowledge to speak.
Old Jul 26, 2010 | 07:10 AM
HAMOTORSPORTS's Avatar
LOL, sk2 doesn't offer stage 4 camshafts...
Old Jul 26, 2010 | 08:16 AM
NAH2B's Avatar
if thats the case than forget about oversized valves
otherwise check your v2v and p2v, are your pockets cut for oversized valves? as for v2v, it shouldnt be a problem, worst case may need to sink the valve a little or just pull the cams off centerline and add more seperation
Old Jul 26, 2010 | 01:20 PM
EdSales's Avatar
Your absoluletly right. I mis-read Skunk2's website. It says Stage 2 and Stage 3 Camshafts are not recommended to use on oversized valves.
Old Jul 26, 2010 | 03:17 PM
SP GARAGE's Avatar
just do V2V and P2V... are you on stock guides???
Old Jul 26, 2010 | 03:25 PM
Loved
Community Favorite
I don't know if Im on stock guides or not, the oversize valves are already in the head (I wish it just had oem sized) what is a good way to check if the valve guides are aftermarket or what not? just don't wanna have any clearance issues. Ill pull the head when I get the cams and have it all degreed in and checked for clearances.
Old Jul 26, 2010 | 03:42 PM
00Red_SiR's Avatar
All Motor Mentor
when you look at them in the ports do you see black steel or shiny brass?
Old Jul 26, 2010 | 04:12 PM
DSRxCandyh2bEG's Avatar
Color is a good indicator of stock or aftermarket guides...
Old Jul 26, 2010 | 04:41 PM
Loved
Community Favorite
haven't looked into the ports yet.
Old Jul 26, 2010 | 06:01 PM
SP GARAGE's Avatar
reason i ask if you have bronze guides is because if you have them you can run a tighter v2v clearance on them
Old Jul 26, 2010 | 08:41 PM
Loved
Community Favorite
ok. also do h22's have issues with the valve seals clearing with big cams? is that something im going to need to check too?
Old Jul 27, 2010 | 03:12 PM
SP GARAGE's Avatar
no i have no valve seal problems...
Old Jul 27, 2010 | 03:53 PM
00Red_SiR's Avatar
All Motor Mentor
he's probably wondering about valve seal to retainer clearance. More of an issue with pro series cams.
Old Jul 27, 2010 | 05:18 PM
Loved
Community Favorite
ya thats what I was wondering about, I remeber reading somewhere about the h22a's don't have issues but h22a4's do the thread was talking about installing type s cams.
sneaky pete
Mar 7, 2008 03:47 AM
Mikes2000civicsi
Dec 21, 2006 11:16 AM
IntegraVTEC
Jan 15, 2006 09:34 AM
SiBuddy00
13
Jul 31, 2005 09:41 PM
JunIntegra
Apr 8, 2003 11:31 AM
