Wheel Prep for track day?
I will be taking my car to the track for the first time September 28-29 at road america.
I think I have everything covered, preparation-wise - except for 1 issue.
What should I do about the hub-centering rings that came with my wheels?
If I leave them in they could ?melt?, if I leave them off I feel the runout on my wheels will be way out of whack.
What should I do?
Thanks
Adam
What should I do?
Thanks
Adam
Never had a problem with the rings either. What I do wheel-wise is put some anti-seize on the studs and make sure the lugs are torqued to spec. I re-check them just before every session.
Invest in a good torque wrench; tighten the lugs with the car on stands, progressively in a criss-cross pattern; be sure that you have the correct lugs for your wheels; and do NOT overtighten them. If you do all of these things, the centering rings are of no real consequence.
What you could do that most people don't is wash your wheels well and inspect them periodically for cracks. Also, tape over your wheel weights - to help keep them on or make it easier to spot one that has come loose. I like real aluminum duct tape for this purpose - the kind with the peel-off backing.
Kirk
Kirk
Tire rack recomends that you don't put antisieze on the studs or lugs. Read instructions found at link below. Have fun at road alanta I heard it is a fun track.
http://www.tirerack.com/installer/package_install.html
Wouldn't the weight of the aluminum tape throw off the wheel balance? Or would it be insignificant?
I too have seen the repeated conversations about antiseize. I have typically used it but started doing it on street cars, where the lugs don't get undone twice a day or more, to ward off corrosion. I guess that I am baffled (but without specific experience to explain why) lug nuts would seize on a wheel stud when torqued to the typical spec - like, what, 75-90 lb-ft with an aluminum wheel and tapered or spherical lugs?
Are we talking about alumimum nuts or something that I don't understand? What am I missing?
Kirk
(Shamelessly hoping you can keep me from experiencing the joy that you must have felt)
Were those OEM lugs, Greg? What torque spec were you using?
Kirk
Kirk
Thanks for the help guys
I am going to Road America with my uncle's Alfa Romeo club- CAROC (Chicago Area). It's not an HPDE, but they have a mentoring program. Just lapping and touring (70 mph max for touring).
His Alfa has half as much power as my prelude, but I have no experience.
Later
Later
Philbert
Jun 17, 2002 04:48 PM
Philbert
Jun 15, 2002 04:32 PM
