B7 head shave/mill
Old Jul 25, 2010 | 12:29 PM
ddjones1028's Avatar
Default B7 head shave/mill
Hi I was wondering what would be a good amount to shave my d15b7 head and what head gasket to use to get the compression ratio to 10.4-10.7. Your help would bble greatly appreciated.
Old Jul 25, 2010 | 01:55 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: B7 head shave/mill
Check the FAQ for the compression ratio calculator and play around with it. You'll be able to determine roughly how much you need to take off to achieve your desired target compression ratio.
Old Jul 25, 2010 | 02:37 PM
Okay thank you. I know this is a dumb question (sorry, new to hondas) but if I bought a d16y8 head gasket set would everything else that comes with the kit like the cam seal and stuff like that fit my d15b7?
Old Jul 25, 2010 | 07:21 PM
24TEN's Avatar
PHANTOM MENACE
I wish I could tell you off the top of my head but I can't (headgasket itself is usable though). You can check out www.thehondapartsstore.com (or similar website) and look up the part numbers for each seal and see if they are the same.
Old Jul 25, 2010 | 07:49 PM
builthatch's Avatar
MiG-21 superfan
d-series.org should be in your favorites.
you can use that head gasket, yes. the seal should be identical as well.
when looking up part numbers remember that even though it might be the same part honda very well could have different numbers, especially between generations.
you are going to have a hard time reaching that compression via simple milling. it's hard to say because of the combustion chamber shape changing when milling, but i'd say you would have to approach .050 before you get in your desired range.
as a guide, i do not ever remove more than 30 thousandths from a head, unless it's a junk head without port work, etc. it leaves practically no room if you end up warping it and need it milled.
.030 would leave you at 10:1, basically.
Old Jul 25, 2010 | 07:57 PM
Okay thanx everybody for your help. This is going into a circle track race car and I am just trying to get a little more power and I knew that head work wouldn't be too terribly hard. Just out of curiousity, what I'd the maximum I could shave the head with a stock b7 headgasket?
civic_jdm
Feb 17, 2005 07:49 AM
Kellindal
May 18, 2003 10:12 PM
Clutch101
Nov 14, 2002 03:21 PM
you2envious
May 26, 2002 06:26 PM
IM ALL BOB
Aug 8, 2001 08:35 AM
