swapped now no power
Old Jul 25, 2010 | 07:51 AM
h22.ej8's Avatar
Default swapped now no power
hey guys. car is a 94 del sol s automatic d15b7. i did the manual conversion and swapped in a d16z6 with a 99 ex tranny. the only thing not wired up is vtec. at first we had fuel but no crank probably bad starter. but then somone switched the starter and alternator connection in the fuse box without me knowing. then the next time i went to try to start the car, it lost all power. i was able to check for trouble codes before we lost power and all i had was code 19 for the auto tranny control valve. could i have fried the main relay. someone also told me to check the fusible link for alternator but would that cause it to lose all power. the main relay doest smell burnt but somthing in the car does smell burnt on the passenger side. thanks alot for ur help.
nicole
Old Jul 25, 2010 | 08:07 AM
Former User's Avatar
Default Re: swapped now no power
Have you checked whether the 80A fuse and other large hood fuses are blown?
Old Jul 25, 2010 | 05:15 PM
h22.ej8's Avatar
i have a p28. i got crank and power now but no spark and no fuel. fuel pump doesnt prime and main relay doesnt click. i think im gonna check all the fuses. let me know plz
Old Jul 25, 2010 | 05:16 PM
h22.ej8's Avatar
could it be anything regarding the auto to manual conversion?
Old Jul 25, 2010 | 05:18 PM
What was the cause of power loss?
Check the ground attached to the thermostat housing. It should be clean and tight.
Old Jul 25, 2010 | 05:24 PM
h22.ej8's Avatar
done lol still nothing
Old Jul 25, 2010 | 05:26 PM
What was the fix for the original power loss?
Check fuses 31, 24, and 18.
Old Jul 25, 2010 | 05:28 PM
h22.ej8's Avatar
grounds were bad... i just dont know what else to check. i tried different distributor and main relays and ecus...
Old Jul 25, 2010 | 05:33 PM
h22.ej8's Avatar
yea those exact fuses are on my list. im gonna have to do it tomorrow. its dark already. im in miami. ill post back here tomorrow when i check them.. thanks alot!
elsmiles
14
Aug 16, 2021 12:14 PM
Crashmaster91
Jun 22, 2017 08:24 PM
larocque44
Jun 14, 2013 02:21 PM
jwaggz21
Apr 9, 2013 12:22 PM
ShockWave4210
Apr 7, 2004 09:07 AM
