B16b with 89 crank
Old Jul 24, 2010 | 06:57 PM
Wytek9's Avatar
Default B16b with 89 crank
I will be using B16b block with b20b crank & rods, my question is what main bearing and rod bearing should i use? is it the size of the b20b bearings for the main bearings or the b16b size main bearings? I think the rod bearing should i used is for b20b since im using eagle rods for b20b. Also is it the main caps of b16b the same as the B20b? what main caps should i used to the 89mm cranks to be drop off to B16b block?
Old Jul 25, 2010 | 02:11 AM
king06's Avatar
Default Re: B16b with 89 crank
As to what bearings, they have the same main and rods sizes. so just measure and get the correct clearances, I would stick with vtec bearings.
And you use the main caps from the b16b block.
Old Jul 25, 2010 | 07:58 AM
Wytek9's Avatar
Thanks a lot.. :-)
Old Jul 26, 2010 | 04:52 AM
kyden's Avatar
main bearings of the b series are all the same. rod bearings will have to be b16a or b20. you can use b18c ones but you'll have to get the rods retanged.
Old Jul 26, 2010 | 05:44 AM
Wytek9's Avatar
Should i go with oem bearings or acl? any recomendations?
Old Jul 26, 2010 | 05:58 AM
kyden's Avatar
whatever nets you the right clearances.
Old Jul 26, 2010 | 06:14 AM
Wytek9's Avatar
do you have spec sheet for the main bearing & rod bearing clearances?
Old Jul 26, 2010 | 11:01 AM
EK9 CTR's Avatar
My motor is that exact same setup as the OP.... Use LS/B20 main and rod bearings...
Old Jul 26, 2010 | 11:03 AM
EK9 CTR's Avatar
Try to search online for a B18 haynes manual, for the complete detail specs... I got the specs but its on my other pc.... If you have difficulties with the build or specs, PM and I may be able to help you...
Old Jul 27, 2010 | 05:12 AM
Wytek9's Avatar
you've got pm..
jakscivic
Feb 21, 2013 08:27 AM
omglook89
Jul 14, 2011 08:49 PM
db2integra
Sep 20, 2004 08:25 PM
teg92
Apr 28, 2003 10:12 AM
