what does the rear plug on the tranny go into
Old Jul 24, 2010 | 06:13 PM
oranginal's Avatar
Default what does the rear plug on the tranny go into
i know there's the VSS in the front but on the back near the shift linkage i see another plug and i can't find any plug near it to plug it into.
putting a new motor in so not sure if this was not used before or not, can't remember.
thanks.
Old Jul 24, 2010 | 08:11 PM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
Default Re: what does the rear plug on the tranny go into
Number of wires? Wire colors?
Could it be an A/T harness you're putting on an MT by any chance?
Old Jul 24, 2010 | 10:22 PM
oranginal's Avatar
Looks like three pins. Don't know the plug so don't know wire colors. Harness is MT And couch is m2f4. Can someone check real quick.....its by the shift linkage.
Old Jul 25, 2010 | 06:11 AM
5SpdH22's Avatar
something gnarly
I have a harness sitting next to me.. the only other 3 wire ones are EGR and the throttle angle sensor (on the throttle body).
I'd say the EGR valve is decently close to the VSS..
Old Jul 25, 2010 | 06:39 AM
street_ride14's Avatar
VSS is in the back near the shifter linkages .. Reverse switch is more near the front
oranginal's Avatar
Here is a pic. I also don't know what this is but it has two lines running to it.
It is not the TPS or EGR...i was trying to rule everything out to.
I think possibly this could have a plug that goes to the car...instead of the wire harness if that makes sense. kind of like how the brake fluid reservoir does, but this seems more important
Old Jul 25, 2010 | 06:42 AM
^ that is the VSS in the picture
Old Jul 25, 2010 | 07:09 AM
oranginal's Avatar
a guess a picture is worth a thousand words.
so where is the plug for it at?
I guess the plug in the front with two wires is the reverse switch.
Old Jul 25, 2010 | 07:50 AM
5SpdH22's Avatar
something gnarly
Yessir.
The VSS plug has 3 wires, orange | black/yellow | black
It's short, only sticks off the thick part of the harness about 6 inches or so...
Old Jul 25, 2010 | 07:52 AM
IDK for sure but it looks like you only got the bottom half of the VSS in the tranny, the top half is what actually has the wire with plug for the harness. Any way you can get a closer pic of the VSS ?
Yup, that's the reverse switch.
corkss
10
Apr 13, 2009 01:47 PM
j spec
Jul 30, 2006 04:57 PM
underage
11
May 25, 2005 12:41 PM
West Werks
Mar 10, 2005 08:10 AM
chitownrida
Oct 2, 2004 09:31 AM
