95 hatch with 92 dash swap srs light on
swaped dash with non passenger side air bag srs light is on can it be turned off?pass bag was removed and wiring was unplugged drivers side is still hooked up.
Can dash light be turned off or bulb removed?I did not see bulb on back off cluster
the 95 is wired for a pass side SRS. Since the wiring is unplugged, it's throwing the code for a error in the system. You may be able to crack open the cluster and put some electrical tape over the SRS light and be done with it, but if you ever need to do any type of inspection, the car will fail since the SRS light is not there.
That is the easiest way from what I have seen.
dem0nk1d
Sep 3, 2006 10:46 AM
