Honda S2000 Honda S2000
DIY painting a front lip- wetsanding after?
Old Jul 24, 2010 | 04:13 PM
corcoran_chris's Avatar
Default DIY painting a front lip- wetsanding after?
Hey guys I'm painting a front lip with paint matched rattle can paint- I used flex fill primer then wet sanded- then did my main coats and everything is done more or less- Ill let it cure for 24 hrs - then do I wet sand? if so how/what?
Old Jul 25, 2010 | 07:15 AM
rnacion's Avatar
Default Re: DIY painting a front lip- wetsanding after?
Did you have any runs or fish eyes? That will basically determine what grade of paper to start with. I would start with 1000 (the coarsest I would use), and work up to 1500 then 2000. Soak your paper in water with a drop of dish soap in it, this will keep the water slick, and make sure that the area you are working is constantly wet. You cannot use too much water, but can definitely use too much. After the wet sanding there is still one more step. Hit it with some sort of rubbing compound to level out all of the remaining fine sanding marks and really bring the color back out. You could also hit it with a less aggressive silicone free polishing compound afterwards to add some shine. Do not seal/wax the lip for a at least 60 days I would suggest.
Old Jul 25, 2010 | 01:35 PM
bigmacnfries's Avatar
wait, wut?
Old Jul 29, 2010 | 11:38 AM
ReddotsS2K's Avatar
^^^ I was thinking the same exact thing reading it, i had to re-read it like 3 times to realise that it wasn't my eyes messing up.
Old Aug 2, 2010 | 06:03 PM
millertaurussho's Avatar
i think he meant you cannot use too much water, but can definately use too little....and thats true..i just got a lip for mine and rattle canned it...turned out pretty nice
fernando.
Paint and Body
Mar 2, 2011 08:43 AM
91Ef4dR
Jan 6, 2009 03:14 PM
CD5SiRHero
Paint and Body
Jan 29, 2008 12:11 PM
.M.
Dec 2, 2004 04:10 PM
sniperslayer
Sep 24, 2004 09:58 AM
