Head question! d15b7
Old Jul 24, 2010 | 12:21 PM
def90man's Avatar
Default Head question! d15b7
ok im in the middle of replacing valve stem seals, i have 2 questions.
When i press the new valve stem seals on, i hear a pop, like they locked on.
is that it? or should i try to push em in more? because taking those things out certainly werent as easy as putting em in...
and
putting back the springs, i noticed there are some springs longer then others, do one set of long springs go on one side and short springs on the other? if so whats the order?
(intake spring/exhaust)
Other then these 2 things, this is pretty fun, cant wait to get my car running! been about 5 months, i appreciate the help fellas!
Old Jul 24, 2010 | 12:35 PM
DCRB's Avatar
Default Re: Head question! d15b7
.... you do know you're supposed to keep everything ordered per clyinder and keep the exhaust springs seperate from the intake ones right?
Old Jul 24, 2010 | 12:36 PM
def90man's Avatar
****.................. i did not keep everything in order........
i thought they were all the same....
what now? -_________-
i have 8 springs shorter then the other 8 springs (long ones)
do the long ones go on intake or the exhaust? or is it a mixture?
Old Jul 25, 2010 | 12:13 AM
def90man's Avatar
bump for an answer
Old Jul 25, 2010 | 01:54 AM
DCRB's Avatar
according to my helms manual for 91 civics...
the "free length" for the springs are:
intake: 48.58mm's for new springs, service limit is 47.64mm's
exhaust: 49.19mm's for new springs, service limit is 48.32mm's
and to answer your original question, the valve stem seals should just pop on there, i don't remember requiring any force when i did mine
Bama Built
May 16, 2018 07:33 AM
bxsi
Dec 27, 2004 07:44 AM
McFly
Feb 12, 2003 08:27 PM
