Car wont start! Got spark & fuel. Crower headpackage/B18c5
check your plug wires and make sure they're in the correct order on the cap. If that's not is, make sure everything lines up at TDC.
those are two things that you need to do. If the fuel pressure is to low, it won't fire, if it's to much, it'll flood. It sounds like the plugs in there are already fouled from fuel or something else, so install some new ones.
Changed oil, put in new platinum plugs, got fpg; fuel pressure is at 44. Cranks stronger than ever and almost starts up for the first 25 seconds, after that it just cranks.
After that i'd pull the rail, make sure that your getting fuel, something isn't happening.. you need two things fuel and spark and one of them isn't getting in.
scotty.b16a1
Dec 31, 2012 01:54 PM
