oil pump!
So I have a gsr block with no oil pump. I have a b16 oil pump at home, and I was wondering if it will work on the gsr block. I know it will bolt up, but I need to know, does it put out the same work a gsr oil pump does? and I i run a b16 oil pump, will i also need to run a b16 water pump. Reason I ask is last time when I mated an ls fpr on a b16, it created problems and car ran like crap, b/c fuel pressure specs on the ls fpr were different than the b16 fpr. SO do want to run into a problem later down the road
b16vtecsol
Nov 18, 2003 12:45 AM
