spark plugs white! Too much timing???
Old Jul 23, 2010 | 11:06 AM
Speardog's Avatar
Default spark plugs white! Too much timing???
I have a 96 hx civic 5 speed. I have been hearing slight pinging between 1500-2000 rpms under light load. I just did the major 100k maintenance routine. Notice the spark plug ground electrodes (top arching piece of spark plugs) are white and the center electrode is slightly eroded for lack of a better word. I know this means a lean condition or too much timing. The Base ignition timing was 14 degrees BTDC when i checked it. The manual says 12 + or - 2 degrees. I retarded it to about 11 degrees to see if this helps. Anyone else have this problem? My fuel filter only has about 10k miles on it.
Jeff
Old Jul 24, 2010 | 08:26 AM
civiclx1988's Avatar
Default Re: spark plugs white! Too much timing???
Check Your EGR????
Old Jul 24, 2010 | 08:20 PM
Speardog's Avatar
For what, being clogged? why will this make the spark plugs white?
Speardog's Avatar
BTW, where the hell is the PCV on my car?
milkwasabadidea
11
Aug 29, 2011 08:08 PM
zombo
May 3, 2011 06:27 PM
axionm1k
Jul 17, 2008 05:02 PM
Sunlight
Feb 5, 2007 05:12 AM
b16awarrior
Oct 29, 2002 07:56 AM
