where does my fast idle go!?
Old Sep 15, 2002 | 11:38 PM
FnkyChnkyMnky's Avatar
Default where does my fast idle hose go!?
so, im in the garage swapping parts from my jdm b16a to my new itr mani and ran into this...
you can see where the fast idle hose connects onto this original mani...
uh oh! here is the itr mani... nowhere for my poor hose to go!
we think it plugs in here on my thermostat housing
and for reference, this is the same spot as the last pic, but on an itr...that hose fitting is not there and the fast idle does connect to the intake manifold.
anyone know where my hose connects and out of curiosity, why is my setup different then the other motor?
thanks!!!!
[Modified by FnkyChnkyMnky, 5:05 PM 9/16/2002]
Old Sep 16, 2002 | 03:42 PM
Default Re: where does my fast idle hose go!? (FnkyChnkyMnky)
ttt
Old Sep 17, 2002 | 05:56 AM
NixTEG's Avatar
I ran into this problem, my set up was a little different though ! I put a 98 B18B motor into a 90 TEg !!
( i THINK ) OBD 2 motors DONT use the fast idle air valve and OBD 1 and OBD 0 motors DO !! I think you have 2 choices here,either swap the thermostsat housings ( pain in the *** ) or plug up the outlet for the hose on the housing or put a TEE fiting on the hose that goes from the intake to the pipe, ( the pipe that goes from the water pump to the thermostat housing
heeltoehonda
Apr 4, 2010 05:59 PM
rsa0905
Feb 27, 2010 07:01 AM
Jonathan_ED3
Mar 10, 2009 06:17 PM
XstouterX
Nov 11, 2005 11:30 PM
