Fan does not come on 1998 civic EX
Old Jul 22, 2010 | 10:54 AM
julioboostamante's Avatar
Default Fan does not come on 1998 civic EX
I checked it out a couple days a go and my fan wont come one. Would the Thermostat switch cause this? i check the fuses related to the fan as well as the relays and they all seem to be fine. The car has ran hot before and over heated a coulpe times so im wondering if this would render the switch useless?
Thanks!
Old Jul 22, 2010 | 11:23 AM
Former User's Avatar
Default Re: Fan does not come on 1998 civic EX
Is the engine overheating? If so, under what conditions?
Fan switch:
Unplug the 2P connector to the fan switch on the thermostat housing and then short the two terminals in the wire harness connector with a jumper wire. With the key in ON(II), does the fan now run continuously? If so, you may need a new switch or the cooling system needs to be bled.
Old Jul 22, 2010 | 12:13 PM
Fan switch:
Ron, the engine runs hot after a good 15 mins. The fan never comes on! ill have to try what you suggested. thanks for the info!
Im off to the stealership for a new T-stat.
Old Jul 23, 2010 | 05:33 AM
Did what you suggested with the jumper wire on the connector to the fan switch. It turns on when i jump it but does not when plugged in. I replaced the Fan switch and still nothing. Car hasnt over heated but still curious as to why the fan wont come one. I installed a OEM T-stat as well.
Old Jul 23, 2010 | 05:35 AM
Bleeding may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below
Old Jul 23, 2010 | 07:35 AM
Jimster480's Avatar
well if it still doesnt come on it could be the temp switch. Mine went out aswell so I just jumped it, its been jumped for years now with no issues. Just get a insulated wire and plug it into the plug, and then cover it with electrical tape and put it somewhere. Maybe one day I'll replace it lol
Old Jul 23, 2010 | 08:22 AM
Old Jul 23, 2010 | 08:47 AM
Jimster480's Avatar
lol i must be too tired today to realize ****. It wouldn't make sense that it doesn't come on unless there is a abundance of trash built up inside of the coolant system that is somehow preventing it from working :/
Old Jul 23, 2010 | 08:50 AM
Or air
Old Jul 23, 2010 | 08:54 AM
Jimster480's Avatar
Or air
yea true but do you think air would really stay there for extended periods of time?
Old Jul 23, 2010 | 09:03 AM
Happens all the time.
Old Jul 23, 2010 | 10:28 AM
Thanks for all the info guys! The temp switch is the one that tells me how hot my egine is yes? The fan switch it a whole diffrent switch yes? if so i just replaced the fan switch located at the thermostat housing. im gonna drive the car some more today to see what happpens with the engine temps. I really dont want to re-do the headgasket. If so im gonna do a Vtec head swap as the original motor was a y8 but now it has a non vtec D15b.
kirkland08
Mar 5, 2011 01:15 PM
strngblkman
Oct 18, 2010 07:29 PM
93-eghatch
Apr 28, 2010 01:31 AM
jry2598
Aug 28, 2006 10:19 AM
Hybrid
May 18, 2002 12:52 PM
