failed smog
Old Sep 15, 2002 | 11:22 PM
eh2's Avatar
eh2
Default failed smog
what causes high nox?
Old Sep 16, 2002 | 12:57 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: failed smog (eh2)
high compression
Old Sep 18, 2002 | 09:04 PM
JALOP B16's Avatar
Default Re: failed smog (B18C-EJ1)
temp of the head to high
Old Sep 19, 2002 | 07:24 PM
b20guy's Avatar
Default Re: failed smog (JALOP B16)
lean mixture, bad o2 sensors, timing off, bad cats, clogged or nonfunctional egr valves, among other things
Old Sep 19, 2002 | 07:47 PM
chronic's Avatar
get a cheap 50 cat from a muffler shop right before you get it tested, it will pass, thats what i did cuz i had high nox. after about a week or so the cat stops working, thats what u get for 50 bucks i guess.
Old Sep 21, 2002 | 10:55 AM
erniecars's Avatar
Default Re: failed smog (chronic)
high nox is caused by modified camshafts and high temp in the chambers, probably from a lean mixture. You could richen your mixture to lower nox but that can bump up hydrocarbons so you'll need a working cat to counterbalance that. Also make sure you have your O2 sensors working properly because they can cause lean fuel sometimes.
jaybee1
May 18, 2013 08:21 AM
Magick211
Oct 28, 2006 02:51 PM
mark72
Apr 20, 2004 07:21 AM
DC2_R
Dec 7, 2002 03:24 PM
