shifting after redline
On a ls the fuel cut off is around 7000rpm if i have basic boltons and a chip that advances my timing ,adds more fuel and raises the cut off to 8200rpm should i pass my redline to shift and be at higher rpm in the next gear and if so should i go all the way to 8200rpm
Stock engine redline is there for a reason. If you dont modify your engine to handle the higher revs, then it wont. Adding fuel and advancing timing does not allow your engine to rev higher.
[Modified by KANJI, 12:15 AM 9/16/2002]
[Modified by Type Goch, 1:20 AM 9/16/2002]
The fuel cutoff is actualy 7200, but i wouldn't shift any higher than 7000
Stock cams, you will go slower if you shift that high. Not to mention the damage you are causing.
edit: Why is this a LS question in the ITR forum?
[Modified by StyleTEG, 1:58 PM 9/16/2002]
You guys make me hungry...
*sigh*
8200 RPM is not enough to grenade an LS motor even with the stock valvetrain. <U>However</U>, it will not make for a very good shift point. The LS's torque curve drops off very rapidly after ~6500. By 8200 it'll be wheezing its poor little guts out and making practically no power. That's not what you want. ~7000 RPM is going to be about as high as you want to take an LS with stock cams/intake manifold/valvetrain simply because shifting any higher will serve only to make you slower and accelerate engine wear unnecessarily.
